Battery ventilation
I was reading another thread about battery ventilation, but I can't seem to find it again. Anyways, it prompted me to look at my battery setup in my SC. There was some white powder at the base of the battery, which I cleaned up with a stiff brush and a vaccuum cleaner. There is no corrosion of the paint or metal, luckily. However here is my question, where do you vent it out to. The battery in the car has a vent which points directly towards the fender of the car. I have plastic tubing I can use to make an "exhaust" pipe for the battery, but where do I go from there? I can not find a hole that leads to out side of the trunk. It seems strange that Porsche did not take this into account when desning the car. I don't want to drill a hole and potentially cause rust. Any ideas?
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
bump.
RETIRED
Best to nuetralize the powder with a solution of baking soad a water....then mop that up...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Subscribing.
1984 Targa |
I've posted this answer before...
You can find a row of bottom-drain plugs that run left-to-right on the floor....near the front of the car. You can see the plugs from below from the outside / bottom of the car. They are flanged to act as one-way drain valves, with the big side flange on the bottom outside. Route the hose to one of these holes and push through to the outside. - Wil |
From inside the trunk I found what appeared to be a plug that may go all the way through. However, immediately below that is the front A/C condenser. Would it be safe to point a vent tube directly down on the condenser?
No, work the tube so the end is clear of anything.
Air Medal or two
Pc680 will not need a vent.....................
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
I couldn't find the drain plugs mentioned by Wil. Can someone post a picture?
Thanks!
1984 Targa |
Since I have removed my AC, I have the battery vent tube going out through the fan opening to below the front bumper.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Scott:
Try looking on the front / floor....middle of car....in front of the gas tank but in the area behind the front A/C blower ass'ly....itsy little black plugs that have the big flange on the outside and the small ( retaining) tabs on the inside. Can't recall right now but should be 3-4 of these guys running left-to right. Visual clue from looking underneath the car, too... For reference, my car is an '85...so it should match up with yours. - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
