Brake lights used to work now they don't?
Tail lights, running lights, blinkers, backup lights, emergency flashers all work. Just no bake lights. The fuse looks fine. What do I check. |
I'm with Bill
Pressure switches on the master cylinder, that is what makes the lights work.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
thanks, I'ss check it out.
The manual failed to mention that. |
Remove one of the plugs to either switch and jumper from terminal 81 to 82a of the connector. The brake lights should illuminate and the Brake Failure warning lamp should start flashing.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
ok, brake lights work when plug is jumped. Now what? Do the pressure switches need cleaning or just replaced?
Is this a pressure switch that I can get at my local parts store or another porsche only part? thanks for the help |
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
