swepco
Hugh,
I don't know if you ever decided on the swepco product or not, but I just drained my '84 911's tranny and filled it with Swepco, it is like driving a new car. My tranny was rebuilt 50k miles ago so it is not at all worn out or anything, but it was a bit notchy specially when cold, but now I can truly say it shifts much better cold and shift even better when warmed up. Just thought I'd pass on my 2 cents from my personal experience with it. Take care, Frederic |
Alternatives to SWEPCO 201 ... SWEPCO 212, SWEPCO 210
http://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_swepco_pg3.htm |
Update?
Wayne, I'm considering the same combination (dino 75/90 and Lucas oil stabilizer) -- how did this work out for you? Stock 85 w/915. Thanks, Dale |
LONG thread, definitely worth reading...
http://forums.pelicanparts.com/porsche-911-technical-forum/524583-swepco-transmission-fluid-question.html |
But I was just curious about adding the Lucas Oil Stabilizer and whether it might hurt/help synchro engagement on the 915. Since Wayne mentioned he tried it, I was hoping he'd share that experience. Dale |
IIRC, someone sent the lucas oil stabilizer in to Blackstone or Stavely a while back. All it does is increase the viscosity of the oil you add it to.
There is no substitute
That's why I was hoping Wayne would share his experience. Thanks. |
Swepco does not need any thing added to it.
Wow, I had to go out and check to see what color fluid drips I had from the gearbox.:D
Sorry Dale, but I used Swepco in the box. No Lucas, either. FWIW, the improvements I saw were more due to having the shift coupler adjusted properly as well as practicing the proper technique for shifts. BTW-The Kendall GL-5 80/90 seems to be the recommended fluid as of late. |
Kendall NS-MP SAE 80W-90 4 qts X $4.49 = $17.96 Aubuchon Hardware 800.431.2712
Best advice I ever got from Pete Zimmermann! I would have paid 10X I was replacing Swepco 201 which was 32 months and 11,075 miles old. Noticed a difference in the first 30 minute drive. I don't "think" about shifting my 79 SC anymore |
Thanks, all
| All times are GMT -8. The time now is 09:59 PM. |
