Targa/Cab Strengthening Idea
So I've got this rusty 70 targa that I'm cutting up and making into a no-frills little speedster including doors welded shut. The driver's floor is bad and will need replacement, a big job but very doable.
As I was looking at the car today, I got to thinking about how to strenthen the tub. Part of my plan is to put a cage into. But if I weren't, what would I do. I had the idea that I could pull the entire floor pan out and weld in flat sheet stock. Then I could fit in some 1.5 inch thick aluminum core honeycomb sheet wtih plenty of structural adhesive. Then put a layer of steel on top of that bonded in and tacked all around the perimeter, maybe coming even with the center tunnel. Thoughts on this? Will it work? To what degree if any?
Tru6 Restoration & Design |
Sports Purpose 911 Driver
I think that is a lot of work and could add a lot of lbs. Recommend you consider sending tyson and email. He did my car and it is really like driving a coupe without a cage...
good luck.
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Thanks James, looking forward to learning anything I can from Tyson.
If you are really serious about welding the doors shut, a beam across the top of each opening and an x-brace will stiffen it more than anything you can do with the floor. These bits will need to be properly fabricated; just welding a piece of pipe across the jams won't cut it. Then take the skins off the doors and weld them directly to the body.
regards, Phil |
Hey Shaun, something I have been considering for my own Targa is to run a brace from a roll bar (if I end up with one) or from the seat belt shoulder mount bolt (like the Targa brace they sell), but rather than bolt to the lower seat belt mount, run the brace all the way to the front of the side of the seat mount area. I'm thinking as far forward as possible dictated by the height of the side of the seat and tying in to the heavy flat area where the seat rails bolt in.
In your case with the doors welded shut, you could go all the way to the front footwell and lower dash area effectively triangulating the door area. Might as well connect to the front strut tower too! Seems like it would be the next best thing to a full cage... Matt
'73 911 Targa / 2.7 RS spec |
Thanks Phil, good ideas on welding the doors shut. I was also going to weld the inner bottom of the door to the sill with something in between. Perhaps I'll just do a rollhoop and less of a cage. We'll see.
Also good ideas Matt, thanks. I've got more work than I can shake a stick at through January 15, after that I'll get this thing on a jig and start to map out some configurations with PVC and post accordingly. Until then it's just clean-up and protection work.
Registered Loser
Hey Shaun, I know you have seen the long running thread about chassis reinforcement. But Walt Fricke just added this interesting tidbit...
Structural Reinforcement
Owner of a wrecked 944 |
"bonded-in front and rear glazing" is in the same as saying "glued-in glass"
Matt
You will be amazed at how much welding the doors to the body will stiffen up your car. For the best possible outcome on the outer skin, make a strip of metal at least 2" wide that covers the door gaps, scribe and cut away the metal beneath and flush (butt) weld the new metal in. This will allow you to do metal-finishing to whatever level you can, and reduce filler shrinkage at the gaps which can be a problem if you simply weld the gaps. I learned this the hard way doing the Ghia roadster on my web site.
John www.ghiaspecialties.com
Metalshapers Retreats with lodging on the Washington Coast Dent repair, and custom metal classes. Metalshaping DVDs, tools, and instruction. ghiafab@coastaccess.com |
Check out the thread titled Structural Reinforcement.
Some intersting 'hidden' things to do are: 1. add the cab floor bracing if not already in your targa, 2. add sheet metal along the outer rocker areas 3. seam weld all the area that are now spot welded 4. cut out a 964 tunnel and weld it in right on top of the existing tunnel there are other ideas in the thread I referenced - the idea was what could you do if you did NOT add a roll bar or cage - i.e. for a street car.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Re: Targa/Cab Strengthening Idea
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Senior Member
Shaun,
Speaking from experience, until you cut out all of the rust, its going to continue. You might think about cutting the old out and putting a new floorpan on the car instead of leaving any of the old metal in. I lost a '72 model to rust overseas and its a sad event so hope you can save the car for good. Joe
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Shaun,
To your idea about aluminum honeycomb, it is an interesting idea. Properly bonded honeycomb sandwiches (usually fiberglass panels top and bottom) are extremely stiff at least in beam, I don't know much about the torsional stiffness but believe it is also very high. I think the problem would be attaching it to the stamped steel unibody in a way that would be durable and not deflect at the joint, losing the benefit. you might end up building a complete structure from front suspension mounts to rear, which probably isn't the goal of an exercise that tries to keep a cab or targa accessible.
Andy |
Hope to post in late January-February, which probably means March. ![]()
Clearly too much time to think, to little time to do.
