E-brake stuck!! HELP!!
i KNEW i should have blocked the wheels and left the E-brake off... but NOOOOO !!
anyway, i got the '66 fired up the other day, but ain't going anywhere any time soon
pretty sure the E-brake shoes are stuck to the hub. is there a trick to solving this puzzle or is this one of those "charater building" exercises ? any help appreciated.
thank!
jerry
p.s. i tried searching this forum, but couldn't find anything. then again my search arguement code could be faulty
Old 11-03-2006, 09:48 AM
FinallyGotOne's Avatar
Have you taken off the wheels to see if you cannot just loosen them (brakes) manually?
1979 911 SC
1974 OEM 911 Exhaust and Muffler - Modified to a 2-out
Fiberglas Goodies, 17" C4 Cup Wheels
Old 11-03-2006, 10:05 AM
Try a few times around the drum area with a soft (brass?) hammer. Sometimes, just the vibration will loosen them from the drum slightly.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 11-03-2006, 10:41 AM
I'm assuming the problem is not that the handle won't come off but that the brake handle retracts and the shoes still won't loosen from the drum?
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-03-2006, 10:58 AM
i have not. i was happy to get the engine fired up after a long nap and it was getting late. i *conceptually* understand the E-brake system, but not the detail. i thought that a partial disassembly might be required. i'll have some time over the weekend. to investigate further.
thanks!
jerry
Old 11-03-2006, 10:59 AM
actually i should have included in the original post that this is the only thing i know to try. ie; remove wheel exposing drum and 'have at it'
failing that, i'm at a loss.
thanks!
jerry
Old 11-03-2006, 11:01 AM
Steve;
sorry for not being clear. yes, the situation is exactly as you describe. you must be the voice of experience ?
thanks!
jerry
Old 11-03-2006, 11:04 AM
There's a little "star wheel" adjustor inside the drum of each emergency brake. There's a hole through the drum through which you access it. It's at the nine o'clock position on the right wheel and three o'clock on the left side, and you can see it if you look carefull with a flashlight. You stick a standard screwdriver through the hole until it engages a space between the teeth of the star wheel--visualize a very coarse, small, horizontal gear lying on its side, not a vertical gear/wheel--and push the screwddriver handle forward to loosen the wheel. Engage the next space and do it again, and again and again. The correct direction of push is forward to loosen on _both_ sides of the car.
That procedure backs the shoes away from the drum. If rapping on the drum doesn't then loosen 'em, I'd drive the car a couple of feet, force the matter...
Stephan Wilkinson
Old 11-03-2006, 11:11 AM
guys;
it appears that i have bigger problems then i originally thought. the wheels spin freely once the car is off the ground. looks like i'm in the market for a good used trans.
thanks again for all the help.
best
jerry
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 11-29-2006, 05:12 PM
