-   -   Source for 5amp fuse? (http://forums.pelicanparts.com/porsche-911-technical-forum/317812-source-5amp-fuse.html)
Vin-barrett 11-30-2006 10:45 AM
Anyone know where I can get a pack of just the yellow 5amp?
http://forums.pelicanparts.com/uploa...1164912320.jpg
steve911 11-30-2006 12:21 PM
You might want to call our host - they might have a package of just the 5A.
Or you might pop into a pep boys, autozone, etc.
Vin-barrett 11-30-2006 12:29 PM
retail stores do not carry the 5's.
They are an oddball fuse
yogi 11-30-2006 06:57 PM
I got them from NAPA auto parts. It took the local store near my house 1 day to get them.
lally911 11-30-2006 07:22 PM
I got them at auto barn a while back.
Early_S_Man 12-01-2006 09:36 PM
Find a parts store that carries Littlefuse or Buss [or Bussmann] brand fuses and see if they can order a few boxes of GBC 5 fuses ... exact replacement in a ceramic/glass fuse:
http://forums.pelicanparts.com/uploa...1165037729.jpg
The above screenshot came from the 2002 Automotive-OEM catalog.
http://www.bussauto.com/shared/products/catalogs/
http://www.littelfuse.com/data/en/Data_Sheets/aftermarket-8.pdf
http://forums.pelicanparts.com/uploa...1165041837.jpg
The following Littefuse distributor has the GBC 5 fuses in stock, $20 minimum order:
http://fusesunlimited.com/locations.html
Eric-325I 12-02-2006 09:27 AM
I bought two boxes of each fuse needed for my baby at NAPA. They had them all in stock and were dirt cheap.
Eric
3.2 CAB 12-02-2006 10:30 AM
I just bought 8 German Car fuse kits at Walmart for $1.00 a pack. Walmart is dropping this item from their inventory and are clearancing them out. They come with a fuse puller, an an assortment of fuses, including the YELLOW 5amp fuse, and the rest of the normally used fuses. So, go check your local Walmart to see if they stil have any of them. I thought that $1.00 a kit was a pretty good deal. Just my $.02. SmileWavy
randywebb 12-02-2006 10:43 AM
Say, Warren, is there any adv. to the ceramic/glass packaging?
Early_S_Man 12-14-2006 12:12 PM
Randy,
Both designs have their drawbacks ... aging and exposure to the elements can cause failures of both types -- even when there is no overload condition!
The glass tube design can fail at the internal solder joint ... and the failure will not be visible! Soldered pointed contact points don't seem to corrode as badly as the ceramic design.
The ceramic fuse design has no solder joints to fail, but corrosion at the ends' contact point can cause overheating of the fuse and fuseholder, and discoloration of the wire insulation for an inch or more back into the loom.
