cookster
Guest
Posts: n/a
cam HELP
I need advice on how to set the cams in a 79 3.0 I keep reading Bruces 2nd edition,Hayes and Hayes restoration manual and still I,m confused ( and scared ) to installing and setting the cams, gears and chains. Does anyone have advice on an easier way .
Old 09-17-2000, 12:51 PM
mackgoo
Guest
Posts: n/a
it's not that bad. Just take your time and follow the directions.
Old 09-17-2000, 01:47 PM
cookster
Guest
Posts: n/a
Thanks Mackgoo. boy thats easier said then done. What manual did you use when you set your cams.
Old 09-18-2000, 04:18 PM
mackgoo
Guest
Posts: n/a
I had the 911 hand book, shop manual and Haynes on hand. What exactly is intimidating you.
Old 09-18-2000, 05:52 PM
cookster
Guest
Posts: n/a
Mackgoo. I guess its knowing what can happen if their not set properly. I will be taking the plunge and just doing it this weekend taking it nice and slow. I'll keep you posted.
Old 09-19-2000, 02:04 PM
