The Cuddly One
Isabo's Avatar
******* repairs
I have a chance to get a set of original 9 X 16 Fuchs at a good price. They are a lot less than perfect. They are badly kerbed, I have been told they can be refurbished by my mechanic. I imagine this would involve adding metal in some way, the wheels are structurally ok just look bad, almost as if the kerb took some little bites out of them. Can I expect a decent result, will the work effect the wheel balancing, or is it best to use them as they are?
-Isa
911E 3.0 (Tristezza, the Rattus Maximus) and Jimmy the Mini lll
Dum vivimus, vivamus!
Man braucht nicht reparieren was funktioniert!
Old 12-04-2006, 12:03 PM
Isabo,
Yes, a competent restorer can repair by welding filler material into the void. The wheel is then trued on a large lathe. I would verify that your mechanic is going to use the proper equipment to do so.
If done properly you will be hard pressed to distinguish from new.
Warren & Ron, may you rest in Peace.
Old 12-04-2006, 12:33 PM
The Cuddly One
Isabo's Avatar
My mechanic would send it out to a specialist shop. I'm sure the result will be cosmetically perfect as they're used by the concours crowd, it was the drivability that really concerned me. I've decided to go for them now, I'll try them for a week or so as they are and then have them sent off.
-Isa
Old 12-04-2006, 12:53 PM
Registered Cruiser
jorian's Avatar
If you plan on anodizing the lips, the welded/repaired bits will show through as a stain. Ask me how I know.......
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 12-04-2006, 01:04 PM
safe's Avatar
It depends on how deep the scratches are, if they are not to bad they can be sanded down.
Magnus
Old 12-04-2006, 01:36 PM
jpahemi's Avatar
Were they inexpensive enough to justify the repair? Once you've had them essentially restored, what's the final price?
j.p.
Old 12-04-2006, 02:33 PM
The Cuddly One
Isabo's Avatar
After restoration the total will be about euro 700 for the pair. About US$850.
-Isa
Old 12-05-2006, 03:43 AM
Nape75'911T's Avatar
This wheel was curbed a little....
repaired and trued......and refinished......
Good refinisher.....cost approx $125 USD per wheel.......
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 12-05-2006, 04:08 AM
Senior Member
Isa,
Are you sure you do not have any single daughters who are looking for a long meaningful relationship with a grey haired old fart?
Not being forwards but its not often that we see a lady on the PP forum working with getting some 9X16 Fuchs reworked... and I like it!
Need more ladies like you on the forum!
Joe
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 12-05-2006, 04:15 AM
The Cuddly One
Isabo's Avatar
Nape,
$125 looks VERY GOOD but the shipping would destroy me. Look at what a restored set sells for though!
Joe,
It's because my daughter's grown up and in a serious relationship that I can chase down a set of 9X16 Fuchs. I have to do these things now in case she makes me a grandmother
Thanks for the compliments.
-Isa
Old 12-05-2006, 05:16 AM
Senior Member
Isa,
Next time I have an overseas contract and am heading to Europe or Italy will try to get ahold of you. I have carried 911 parts across the pond for friends before!
Old 12-05-2006, 05:24 AM
