3.2 with 993 he, what muffler?
I have a 3.2/G50 with a 964 narrow body conversion. I'm thinking of upgrading to 993 HE withcat bypass. At that point, my question is will the 993 muflers fit on my chassis or will i need to cut flanges and weld. Incidentally, I have a C2 oem dual outlet bumper, which is not compatible with my 1 in 2 out 3.2 4"duals. are the 993 mufflers the same width as the 964 duals. Yes , they only came aas widebody features, I understand that. Anybody willing to measure their inside edge to edge or center to center 993 mufflers, I would totally appreciated. the bumper mod with my eshaust problems have me inching forwad only in progress. Lastly, what about the 02 sensors?993 comes stock fitted, 911 does not, so if i use the 911 duals, do I need to add the sensors ?
PRO Motorsports
Unless you have a 964/993 oil tank, you can't fit the 993 muffler on the right side.
You'll need a custom muffler set-up.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
ben at mk has one.
