Pertronix ignition?
Hey,
My 74 came with a brand new pertronix ignition. Is it worth putting in?
Thanks,
Pat
'74 911 options delete no sunroof. lowered, swaybars, tie bar, braided brake lines, corner balanced, "s" gauges, 993tt seats, Momo wheel and knob, 993 mirrors, blacked out window trim, H4's, short gearing, S pistons, stand alone EFI, other stuff.
Old 12-06-2006, 08:13 AM
anthony's Avatar
Pertronix? I have one on my 914 and it's great. If you use it, you can't leave the key "on" in the accessory mode for a long otherwise you'll burn up the module.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 12-06-2006, 08:16 AM
Anthony,
You're right, Pertronix. Thanks for the heads up about the leaving the key on.
Pat
Old 12-06-2006, 08:21 AM
i replaced my points w/pertronix. Gotta make sure the rotor is seated properly after the p install. I also use a wire treminal block instead of soldered wires for a quick r&r w/spare. Timing has to be checked after p install.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-06-2006, 08:23 AM
