epbrown
Guest
Posts: n/a
Steering Wheel
One of the welds on my '83 911 gave and I bought a replacement on eBay. The package arrived a few minutes ago and the wheel appears to be broken - there was a small piece of place plastic in the bottom of the box, and it appears to have come from the wheel. If I've fitted it properly, it would stick out of the back of the wheel about an inch, like a tab that goes into a slot. So, is the wheel still useable like this, or do I need to initiate return procedures with the seller? I have no experience with this, and haven't disassembled my old wheel to check.
Emanuel Brown
1983 911 SC Targa
http://home.att.net/~epbrown01/91183.jpg
Old 09-25-2000, 03:51 PM
BaldNerd
Guest
Posts: n/a
I'll bet that's the tab that cancels the turn signals after you turn a corner. I'm looking for the ring that that tab was attached to before it broke off.
Old 09-25-2000, 05:16 PM
rstoll
Guest
Posts: n/a
Is this a common break? I lost a spoke on my 83 too.
Old 09-25-2000, 07:48 PM
epbrown
Guest
Posts: n/a
BaldNerd: Thanks for the reply - the moment I read it I realized that that's exactly what it was. Fortunately, the company I bought if from on eBay was understanding and will refund my money when I've shipped it back. I'm only sorry that it was so poorly packaged, since the search for a new wheel will continue. I may go ahead and get the red&black Momo I was considering before this.
Rstoll: I've met a few other SC owners, and this does seem to be fairly common. I'm not too surprised, as the cars are quite old. Wish there was a way to repair the bugger. Stay original and probably stronger than used.
Emanuel Brown
1983 911 SC Targa
Old 09-26-2000, 03:41 PM
old_skul
Guest
Posts: n/a
I bought an aftermarket wheel, and the adapter didn't even come with the horn ring, which has the signal canceler tab on it. I removed the one from the existing wheel (3 screws) and attached it to the adapter hub. No problem.
Mark Szabo
1986 911 Targa 3.2
Old 09-26-2000, 03:47 PM
EdRogers
Guest
Posts: n/a
If you do go with the momo, I have a spare hub for your year. I bought one for my 70 T, and it showed up with the later hub, like yours. Perfect condition $35 if you want it. Ed
Old 09-26-2000, 03:50 PM
