Senior??? Oh very well
fly4val's Avatar
fender oil cooler bumper cutout?
Read about this in 101 Projects and would like input from the team?
I have a pristine '88 Carrera coupe (105k) that is totally stock, never rusted or wrecked, except for lowering and replacement steering wheel. I dont want to chop this hole if the value of it is minimal to the car.
I live in Everett WA about an hour north of Seattle. It can get very warm in the summer though this year was milder than '05.
Max temp seen on gauge this year was half way between upper mark and redline.
Also seeking input on the improved A/C kits offered in some of the major Porsche magazines....?
Thanks,
Val
Old 12-06-2006, 06:52 PM
fancytown
Re: fender oil cooler bumper cutout?
Originally posted by fly4val
Read about this in 101 Projects and would like input from the team?...Max temp seen on gauge this year was half way between upper mark and redline....
That's the highest I've ever seen on my 3.2L on the track. I don't know anyone else with a 3.2L that has had temp issues either. I'd say leave your bumper alone, as it shouldn't be needed.
all cars sold.
Old 12-06-2006, 07:05 PM
This Way Up
rdrr's Avatar
I think you are referring to the bumper cutout that was already standard on your car. I have an 89 Carrera and the bumper cutout is there - just have a look under your indicator light on the passenger side of the car.
Old 12-06-2006, 07:21 PM
You can already add this,
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_uprc91_pg7.htm#item
Old 12-06-2006, 11:13 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
I did this when I did some oil cooling work. Two fender mounted Carrera coolers
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 12-07-2006, 10:28 PM
Coincidently, I just cut a notch in my bumper yesterday in the course of replacing my bumper "smile". While the bumper was off I replaced the horns, too. The aluminum bumper cut slowly but cleanly with a conventional jig saw, and two drill holes for the sharp corner cuts. I trimmed the notch with grey wire bundle sleeving. I have no temp problems (heavy duty fender cooler) but with the bumper off I couldn't help myself.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 12-08-2006, 05:52 AM
member Makaio lives in Sacremento and uses the marker replacement scoop on his 3.2. He said it's good for 10F oil temp decline.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-08-2006, 09:44 AM
fly4val's Avatar
Awesome stuff...especially the great pic from surflvr....I dont think mine has that cutout but will look closer tonight....great forum...thanks for all your inputs!
Old 12-08-2006, 12:18 PM
fly4val's Avatar
Thanks all and a tip of the hat to rdrr and k-jetronic, my '88 has the notching on the underside of the bumper. Decided to add the PP scoop after the holidays and then do evals in the spring.
You guys are awesome....again thanks!
Happy Holidays to all....
Old 12-08-2006, 08:01 PM
