-   -   My 3.2 Swap Tach Has Never Worked. Please Help Me Diagnose. Almost FREE, No Payments! (http://forums.pelicanparts.com/porsche-911-technical-forum/318931-my-3-2-swap-tach-has-never-worked-please-help-me-diagnose-almost-free-no-payments.html)
78-911SC 12-07-2006 09:30 PM
My tach wire is connected to pin 1
Joeaksa 12-07-2006 10:20 PM
Originally posted by Rodsrsr
the tachs are mached with the motor. A 3.2 must use a 3.2 tach, whereas a 3.0 must use a 3.0 tach. I found this out when I installed a 3.2 in a 76 body with the original tach. It worked, but was way off. I eventually got the correct 3.2 tach and everything works fine.
My 1985 3.0 tach worked fine with a 1992 3.6 engine and brain.
Don, you are such a wussy! Just drive the car and when you hear the valves start to float, shift! :)
Hey, cannot wait to get back home and see the conversion. It sure sounds nice!
Joe A
FenderGuy 12-08-2006 08:12 AM
Joe
good call on steve not going that route....
Don
can you advice on anything I should be aware for a 3.2 conversion? What are the specifics on the parts needed? the 3.6 route is dead
Shuie 12-08-2006 08:34 AM
FenderGuy, the website below is probably the best single source for 3.2 swap info:
http://www.pelicanparts.com/MotorCity/marcesq1/
Also, try searching old posts from DonDavis, Joseph Herreros, 1972_911T, and myself. I tried to document the major milestones of my conversion as I went along with part numbers and real costs, but I've been too lazy to go back and consolidate everything into one thread.
Search for '3.2 AND swap' for my user id if you want my old posts. My swap is done, and it turned out pretty clean, IMO. If you find something that I left undocumented or unresolved, bump the thread and ask me and I will go get pics or provide the details.
For me, the fuel system was the biggest challenge. I think I probably went through 50ft of fuel injection hose before I was comfortable with the result.
Rick Lee 12-08-2006 08:39 AM
Yup, that's Marcesq's write-up. I participated in that swap.
FenderGuy 12-08-2006 08:42 AM
Thanks Shuie
