915 reverse light switch/connections
I seem to have broken connector pins for the connection to the reverse light switch, are these pins something I can find easily or substitute with another option? Looking for ideas. :)
HI you could just solder them back on or are thay damaged to a point of replacement with some new ones ?, I have had a look on the PET and found what looks like the re-placement pin part No' 911 612 907 00 but not to convinced, the other option is to PM me your snail-mail add and I have a end of the engine loom with the boot and connectors on, all you will have to do is to connect them to gether.
regards mike |
that is the right part number.
thanks for that,I have not orded the pins as I have S/H usually lying around.
regards mike |
thank you for the info. =o)
| All times are GMT -8. The time now is 01:18 PM. |
