jerhic's Avatar
3.0 valve job break in?
i have just got my 82 SC 3.0 back from the shop after six weeks. i had asked for the valve guides to be replaced as it was smoking at start up.
When it was done they advised me that they had replaced all exhaust valves and had done a valve job. They also replaced one piston ring as it was broken, they did say there was very little wear through out the engine which now has 202k miles. also replaced was the timing chain and guide rails and they resealed the engine, along with several other updates.
they have advised me not to rev the engine above 4k and not to down shift? the 4k i understand but i don't quite get the down shift. what is the proper way to break in this engine?
Old 12-10-2006, 10:31 AM
jerhic's Avatar
any ideas?
Old 12-10-2006, 01:04 PM
petrolblue83911's Avatar
Sounds like they want you to take it easy as the chains settle back in?, -did you have or did they upgrade to carerra tensioners? sounds like maybe not?
That's my best guess, aside from the standard "all those metal parts need to wear in before you push it to hard.."
Old 12-10-2006, 01:13 PM
jerhic's Avatar
the tensioner were upgraded years ago. the downshifting just doesn't make sense to me yet.
Old 12-10-2006, 01:19 PM
i don't see why you shouldn't. there's really no break-in period for anything except rings, which you didn't get.
206 637 4071
Old 12-10-2006, 01:34 PM
jerhic's Avatar
i use to live on 95th and 98th street in seattle, but why would down shifting have any effect on anything/
Old 12-10-2006, 01:49 PM
Air Medal or two
afterburn 549's Avatar
Sounds like they did the right thing s ..replacing the exhaust valves to me is cheaper then making old tired ones go an other round.
Is it possible you misunderstood someone ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-10-2006, 04:13 PM
jerhic's Avatar
anything is possible,but it was stated clearly that i should not down shift for the first 1000 miles.
Old 12-10-2006, 04:25 PM
makaio's Avatar
I imagine their thought is if you down shift you may exceed 4,000 rpms.
Old 12-10-2006, 06:49 PM
Air Medal or two
that's gonna be hard on the clutch starting out in high gear (LOL)
Old 12-11-2006, 06:59 AM
