robfix
Guest
Posts: n/a
Fuel leak
there is a hose that goes from the fuel pump to a fitting which connects the hose that runs through the tunnel. my question is how are these hoses attached to the fitting? on the fuel pump side there is a hose clamp but it is a different fitting on the other end. The hose appears to be about 7 inches. thanks in advance for any advise on disconnecting and suggestions for replacing.
Rob Fix
'78 SC
Old 09-30-2000, 01:38 PM
Early_S_Man
Guest
Posts: n/a
Rob,
It sounds like you are talking about a swaged fitting ... basically a soft-steel 'cup' or ring that is crimped over the fabric-covered rubber hose to hold it in place on the barbed end of the steel fuel line. I have cut many of those crimps off with a hacksaw, making a pair of diagonal cuts on opposite sides, but not usually with the line still on the car ... you might try heavy 9" side cutters.
Warren Hall
1973 911S Targa
Old 09-30-2000, 02:06 PM
robfix
Guest
Posts: n/a
thanks warren,
It looks like if I try to seperate the fitting from the rubber section going into the tunnel that I would damage the little bit of rubber that is there. I guess if I cut the crimp then I just have to recrimp the new cloth/rubber section onto the remaining piece of the fitting.
I'm wondering if the rubber section going into the tunnel terminates into a steel line and would be a better place to disconnect? Is it possible to access the front section of the tunnel, possibly from inside the car?
[This message has been edited by robfix (edited 10-02-2000).]
Old 10-01-2000, 12:30 PM
