Guest
Posts: n/a
Valve adjustment, Carrera tensioner update
Adjusted valves this morning, changed fuel, oil and air filter. Went ahead and pulled muffler and left chain cover. Found the rest of the chain ramp that had made its way to the sump. 3 nice pieces still in the chain housing. Tensioner looks like it may be partially collapsed. I have some digital pics (jpegs) of the carnage, but don't know how to post them.
Guest
Posts: n/a
Can't help with the mechanical bit, but as to posting pictures, try Photopoint.
[*] Go to www.photopoint.com [*] Sign up[*] Email your photos from the address you signed up under to photos@photopoint.com Now you should be able to access your photos at photopoint in your incoming folder. Next step is to move them to a custom folder. You can then link them to the board here by copying the link into the message (this also applies if you have the pictures on your own web site etc already) as follows: {img}http://your_link_here{/img} Except you replace the "{" with the square brackets (ie "{" without pressing shift). When you are in the posting form there is a link called "UBB Code is On" which has instructions. Is that clear? I hope so. I have posted an image from my photopoint below (my own carnage), so if you click the edit icon on my message you can see what to type. Like this: Hope it works! Cam ------------------ Cameron Baudinet 1975 911S [This message has been edited by CamB (edited 10-01-2000).] |
