Send a message via Yahoo to Bobbo911_79
1979 SC Pressure Plate bolts
In the 101 projects book, Clutch replacement (about pg 35?), I think it says to torque these bolts to 66 ft/lbs, but I've snapped a set (thinking my uncalibrated toque wrench was wrong), so I used a calibrated one, and am at 45 ft lbs, and they feel like they're going to snap. Am I reading this wrong? I'm at work so I'm working from memory-not always accurate, but what should the torque value be for these M8 bolts? Is it 18ft/lbs as I read in another string? Please double-check the book, there may be an error there.
thanks,
Bob
Old 12-11-2006, 08:55 AM
vash's Avatar
i think it is 14.5 ftlbs. the flywheel bolts are 66. you sure you are taking apples to apples?
(again, i am borderline jittery from coffee and paperwork, check these numbers)
poof! gone
Old 12-11-2006, 10:34 AM
CBRacerX's Avatar
Pressure plates bolts are low torque, flywheel bolt high torque!
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 12-11-2006, 11:18 AM
randywebb's Avatar
back off on them; remove and discard any that went up way high on torque & replace w/new
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-11-2006, 11:46 AM
Early_S_Man's Avatar
Porsche Crest
Bob,
Those pressure plate bolts are the only DIN 8.8 Allen bolts I have ever encountered on a 911, so the 'normal' torque spec would be 18 lb-ft ... it is no wonder they are about to yield at 45 lb-ft!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-11-2006, 06:35 PM
