rw7810's Avatar
Block Sanding 911 body
What have you guys found to be the best way to block sand 911 body, especially the compound curves, front fender tops, etc.
Robert Williams
70' 911T
Old 12-11-2006, 02:14 PM
evill's Avatar
Durablock (sp?) make some nice dense foam sanders in all shapes and sizes. They have round and half round shapes that work well on the 911 body. For most areas with larger curves, regular sanding blocks work well. You need to keep them flat on the surface, and sand in criss cross directions.
Check Eastwood or do a search for autobody supplies and you should find some sources for them.
Regards,
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 12-11-2006, 04:29 PM
DP935 member
kycarguy 935's Avatar
Rolled magazines with masking tape work well. Also old water hose and radiator hoses work good. And there are many commercially available too.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 12-11-2006, 04:34 PM
