Air Medal or two
electro d.f.u.
Oh I am so confused.. 1st, Electromotive brags about the voltage. Says it has so much it can kill me and fire lasers into space, and put a re tractor beam on the next Ferrari thats gets in front of me.... and Ooh LA LA
In the next breath they tell me in the directions to positively not hook both coils to same cyl as serious loads can happen... So to my way of thinkin is- now most of the spark generated will go to the cyl on exhaust stroke right ??...electricity will take the path of least resistance.....whats your take on this gibberish??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
There is lots of discussion about this on a thread I started a while ago called "educate my about ignitors" I will try to search it out for you later if you can't find it!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Air Medal or two
I remember the thread a long one ?
Air Medal or two
Ok read the whole thing...no real ans ans far as I can see, just a bunch of opinions? . Guess I will call Jokeomotive this AM and get their twisted slant..
If I understand it correctly, each coil contains one primary coil, and two secondary coils. The voltage is induced in the secondaries as the windings of the secondary are "cut" but the magnetic field created in the primary. Since the coils are isolated from each other, the same voltage will be induced in each secondary and will fire their respective plugs. If the two plugs where in parallel with a single coil, then you'd be right, the plug with the least resistance would fire.
I think.
'78 911SC Targa (SCWDP member #17) '74 MGB (one owner) Pickup 2013 Ford Explorer Sport 2013 VW Golf TDI |
Diss Member
Re: electro d.f.u.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Air Medal or two
thats what I mean.....all this talk about superior spark, and NOW I get what is left....spark on the weak side......
Two seperate secondaries, two circuits. The waste spark is only related to the one firing the cylinder are only related in regared to the primay that induced the voltage. Thus, they fire at the same time. The conditions in their respective cylinders is completely irrelevant to the what you're interested in; the timing and power of the spare for the power stroke. I'm not saying the pressure in the cylinder doesn't affect the resistance across the plug gap, because it does, higher the pressure, the harder it is for the spark to jump the gap. The point is, that the waste spark doesn't 'rob' power from the power spark because they are in separate circuits.
The waste spark is a by-product of this type crank fired ignition. One revolution after it's a waste spark, it's firing for the power stroke. I don't know why they don't want both secondaries in the coil hooked up to both plugs in a twin-plug configuration, but the practical reason, as mentioned by a number of posters, is limp home capability. If something causes the primary to fail, you only lose one plug in two cylinders, vice two plugs in one cylinder.
