Painting Fan Shroud
Im repainting my engines fan shroud on my RSR racecar.
Do I need to use a "high temp" paint?
The high temp red paint I have is not very glossy and I would prefer a gloss red finish. The regular enamel does not have any info relative to max temps or such its suited to on the can.
At first thought, it would seem a high temp paint would be required, but then again I am not sure how hot the fan shroud really gets. This engine will run headers and does not have the rubber insulation running around the engine bay keeping air out. Im thinking regular paint may be ok????
Whats the consensus ?
Terry
Old 12-11-2006, 01:27 PM
RX911's Avatar
I like powder coating. The parts cure at 350 to 400F and should take the heat. The gloss is unbeatable.
e
1980 911 SC ROW
Fix the blame....then fix the problem.
Old 12-11-2006, 02:28 PM
I think he's asking about the shroud, which is usually plastic or fiberglass and cant be powder coated. There a bunch of threads if you search, but I think I remember some people having good success with the rattle cans specifically for plastics.
-Brian
Old 12-11-2006, 02:44 PM
WHY DON'T YOU USE BRAKE CALIPER RED, THAT WAY YOU ARE SURE AND DON'T HAVE TO WORRY ABOUT POWDER COATING.
KEITH EPPERLY
87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
Old 12-11-2006, 02:55 PM
djpateman's Avatar
How do you ensure the alternator is grounded? Would the paint not act as an insulator?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 12-11-2006, 05:12 PM
The shroud is fiberglass. ITs not grounding anything, it serves to channel the air to the cylinder cooling fins from the fan.
Brake caliper paint... good idea!
Terry
Old 12-11-2006, 05:14 PM
djpateman's Avatar
You are correct on the fan shroud, I was thinking of the red painted fan (housing?) when I wrote that.
Addicted since 1975
Old 12-11-2006, 07:27 PM
The magnesium looks cool, don't screw it up. One man's opinion
Old 12-11-2006, 08:08 PM
78 in a '71
mossguy's Avatar
tfiv - If you prefer to keep the fan a natural mg, would you bead blast it and rattlecan it with a clear?, or some other finish/coating?
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 12-11-2006, 08:38 PM
