-   -   cis injection problems, a real mystery (http://forums.pelicanparts.com/porsche-911-technical-forum/31968-cis-injection-problems-real-mystery.html)
dick 09-29-1998 05:06 PM
I have a 74 911 with cis injection. Not a single manual or book so far has been able to help me with this problem. With just the fuel pump running, the injectors are discharging fuel. The control pressure is 24psi and the fuel pressure is 70psi. I have tried another fuel distributor but no luck. HHHHHHEEEEELLLPPPPP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lagoon 10-02-2000 08:14 PM
what is the problem? those specs seem to be close to the norm.
Early_S_Man 10-02-2000 08:30 PM
That sounds like the injectors are out of spec ... if my memory serves me right, I believe those injectors are not supposed to leak any fuel at 29 psi! You may want to try an extra-rich load of Techron on a quarter-tankfull of gas!
Warren Hall
1973 911S Targa
stlrj 10-02-2000 09:22 PM
It appears that something is preventing your sensor plate from returning to a fully rested position.
If you put some down pressure on the plate it should stop the flow of fuel flowing out the injectors confirming that the plate is set too high at rest.
Regards,
Joe
