Collapsed Chain Tensioner Diagnosis
1982 911 SC (Stock Tensioners)
Symptoms: The car began making loud valvish noises on the right side (4-6). Sound seemed to be coming from the timing cover and not the valve cover. In addition the car was running very rough and I was also able to determine that the removing any one of the right side spark plugs didn't make the engine run significantly worse. Diagnosis: I pulled off the timing cover and although the chain still had tension, I was able to pushed the compressed side of the tensioner (spring) down with one finger. I assume that is not correct and that this is a bad tensioner that needs to be replaced. Please help. Thanks.
THE IRONMAN
Your chain seem very near of the top...any other greater pic of the area...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Light,Nimble,Uncivilized
If you can push it down with your finger it's shot.
New ones require big-ass channel locks to compress them.
Drago '69 Coupe R #464 |
Drago, Thanks for the confirmation of my diagnosis.
Zef, can you please elaborate? Do you think the chain may be hitting the housing? I can take a picture of whatever you'ld like. Anyone, I will go with the Pressure Fed Tensioners, however, I am curious why some racers use mechanical but they are not recommended for a daily driver? |
GAFB
Compression check time
Several BMWs |
Why, because of fear of valve putting a hole in the top of the piston?
Broken heads studs mandated a complete top end less than a year ago by the previous owner so it would be a bummer. I wished he had sprung for the tensioner upgrade at that time. |
