-   -   Parking Brake light indicator sensitivity (http://forums.pelicanparts.com/porsche-911-technical-forum/320034-parking-brake-light-indicator-sensitivity.html)
Paul Ferradas 12-13-2006 10:06 PM
The parking brake light on my dash is super sensitive. If I just barely start to pull the hadble up it lights up. It's so sensitive that wehn I go over bumps it triggers it. It gets kind of annoying. Is there a way to adjust it's sensitivity?
Zef 12-14-2006 02:14 AM
Yup...the switch is located inside the handle housing...you have access to the switch to adjust it...
Paul Ferradas 12-14-2006 07:15 AM
Hmm, not to figure out how to get the grip off of the handle. I have one of those grips that have the combination lock on them. I haven't noticed a screw but I'll look again when I get a chance.
Thanks.
Zef 12-14-2006 12:12 PM
On mine (1984) I can adjust it with two screws on the slotted portion...you can see them on the side of the housing.
Paul Ferradas 12-14-2006 03:57 PM
Can you provide a picture?
Paul Ferradas 12-14-2006 08:29 PM
No luck in finding this tonight. I pulled up the housing and I looked all over but couldn't find anything. No mention of it in the Bentley manual either.
Paul Ferradas 12-14-2006 08:31 PM
Paul Ferradas 12-14-2006 08:39 PM
Zef 12-15-2006 01:47 AM
Hi Paul...I got this pic...it doesn't have the adjusting srcews in place but you can see the hole for them...You have to remove the seats to gain access to it. Mine is a 84, yours a 87...I don't know if there is a different setting for it.
http://forums.pelicanparts.com/uploa...1166179599.jpg
Paul Ferradas 12-15-2006 07:33 AM
Uhh, I was hoping I didn't have to take the seats off. Looks like it will be a weekend project for me. Thanks for the picture.
