Bendix Fuel Pump Filter for '67S sources??
Does anyone know where to get replacement filters...the one that goes inside the Bendix (Facet?) pump?
Thanks! |
Eric, I think the only difference between the US pump and the European pump is the size of the ports and the color of the sticker. Accordingly, you might substitute the mesh filter from an US version for the one in your pump.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
John, I figured you'd have an idea. Where do I get the mesh filter for the US version though?
Thanks! |
Eric, the filter you want is called FEP43270. That is according to the application guide: http://www.facet-purolator.com/mcl/media/Appref/hd_pdfs/Facet_Guide_2004.pdf
Try these guys, they are in Ohio. http://www.jnelectric.com/ If that doesn't work check the list of distributors on the facet-purolator web site. Good luck! Let me know if it fits, I'll buy a couple.
Thanks John! That looks about right.
I promise to post if it is. |
The car (notice R, 7x15s):
Does anyone have or can provide a picture of the correct mounting of the Bendix fuel pump on a '67S?
Thanks, JB |
Never mind, I found John Cramer's pic in another post.
Thanks, JB |
Hey, that was easy!
Aircraft Spruce & Specialty Co. carries the full line of Facet interrupter pumps that are similar to the old Bendix unit. The internal filter is part number 479729 shown on the page linked above for $2.60 ea.
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Wish I had known of these websites that sell the Facet pumps when I bought one for my 67S. I bought a FEP 87SV that pumps out 4-5.5 psi. Made my carbs leak. Should have gotten the FEP 60SV. It pumps 2.75-4 psi. I've been told the Webers want between 3.5 and 4 psi.
Thanks for the info.
Bob, 59 A coupe 67 911S 04 R1150RS |
