limble's Avatar
Modifying Koni shock rubber bumpers
My car was lowered and the shocks seem to be bottoming out.
I took these two stops or rubber bumpers out and intend to cut them. Question is which one and how much?
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 12-11-2006, 06:14 PM
limble's Avatar
Bump
Thanks,
Mike
Old 12-12-2006, 03:27 PM
limble's Avatar
"Hello? Hello? Anybody home?" -Biff Tannen
Thanks,
Mike
Old 12-16-2006, 05:45 AM
Zeke's Avatar
The ones I've seen are 3-ringed. I cut off a ring at the big end, or one third total. Worked for me in 2 cars. The taper is the cushion. You don't want to lose too much of the cushion if they hit. On other types on other cars, again, I remove material from the base if possible to retain some to the cushion value of the pointy end.
Old 12-16-2006, 06:24 AM
Porsche-pa
75Carrera's Avatar
My car is lowered and I'm preparing to install a set of Koni Specials (front and rear) along with replacing all the suspension bushings. Since Koni doesn't make a Sport Shock for Koni struts housings I assume I'll need to cut the stops down a bit too. Who has experience with Koni and cutting stops (necessary/not necessary/how much to cut)? Is it necessary to cut both front and rear?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 12-16-2006, 06:43 AM
You can fit koni sport inserts in a koni strut, but then you will need a special nut to fit the top of the strut. Mine are in the mail, so if needed I can take a pic when they arrive.
I would be hesitant to cut the rubber and risk that the shock might bottom out
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 12-16-2006, 10:03 AM
911ctS's Avatar
Send a message via Yahoo to 911ctS
It looks as though you have a Koni "snubber" (top one) and some other sort of rubber bump stop that has already been trimmed down (bottom one). If you want to increase travel I would suggest leaving out the rubber one and just using the snubber. Just be sure that you dont let the Koni inserts ever totally bottom out, this will destroy the valving inside.
Peter is correct. The sport inserts need a fine threaded nut to hold the insert into the strut housing. In my experiences the sport inserts came with this nut, but that may depend on which supplier you get them from.
The Biff Tannen comment was great! LOL
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 12-16-2006, 11:40 AM
limble's Avatar
Peterfrans- The pictures above are from the rear shocks.
911ctS- The rubber has not been trimmed down as far as I can tell. I might try leaving it out.
Thanks,
Mike
Old 12-16-2006, 01:26 PM
Elombard's Avatar
I took a ring off mine (the fronts) and it helped. Never thought about the rears, Iwonder if it is bottoming on the rubber. Need to check that.
When you say Koni Sports do you guys mean the yellows or??It seems like I have seen Konis for other cars that are shorter to work better for lowered cars.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-16-2006, 02:53 PM
Porsche-pa
75Carrera's Avatar
The Sports are Yellow. I was told the Sports are best for lowered cars. Then I found I couldn't buy a Koni strut insert for my Koni strut housings! So I went with the Specials front and rear only because my wrench told me to go with a matched set. I respect his 40 years of experience and really had no choice other than Koni Specials ($510) or KYB's (at a third the price). I couldn't find anyone who would stand up for the KYB and Bilstein doesn't make a strut insert for the Koni housing. What strut housings do you have?
Also rans...
Donny
Old 12-16-2006, 03:03 PM
By removing or trimming these rubber busings how much can you expect to lower the car in the front and back?
Old 12-16-2006, 04:40 PM
Porsche-pa
75Carrera's Avatar
Cutting the stops won't lower the car. It will give your shocks more travel without bottoming out under normal conditions.
Also rans...
Donny
Old 12-16-2006, 05:00 PM
