-   -   Window/Door Switch - learn to label (http://forums.pelicanparts.com/porsche-911-technical-forum/320411-window-door-switch-learn-label.html)
aemidnight 12-16-2006 02:19 PM
81sc
took door apart to fix lock problem, that is now fixed, but having problems getting everything back together.
Window switches....didnt label wires as i thought i would remember, lesson learned, now cant figure it out...help:
driver's side, both switches...drivers window:
colors
blue
blue with black stripe
2 red
1 brown
passenger window
1 red with white stripe
1 red with black stripe
2 red
1 brown
http://forums.pelicanparts.com/uploa...1166307260.jpg
can anyone tell me what to plug into where?
http://forums.pelicanparts.com/uploa...1166307306.jpg
also DOOR:
i bent this piece, the door rod to handle, does anyone know what part# this is, i cant find it on pelican parts:
http://forums.pelicanparts.com/uploa...1166307368.jpg
and lastly, the plastic door handle, of course i broke that, i ordered the aluminum replacements, but can anyone tell me how to get the old one off and new one attached?
http://forums.pelicanparts.com/uploa...1166307455.jpg
any help is greatly appreciated, if i can get the windows working i can unlock the car from the outside, and deal with the door handle later, as i'd like to take advantage of this nice weather we are having lately, before it turns nasty.
Thanks in advance.
Ron.G 12-16-2006 03:46 PM
What switch is that? To the front of panel or to the rear?
This is how my 1980 SC is wired.
If it is the switch toward the rear of the panel:
1=single red
2=green
3=two red wires(one actually goes to #1) jumper.
4=black
5= brown
Switch to the front of panel:
(Looking at the back of the switch),the two top terminals
left top=2 brown
right top=2 red
middle left=red with white stripe
middle right=red with black stripe
lower single lug=2 red wires
And there you have it!
Erakad 12-16-2006 03:53 PM
LOL...like looking at a picture of an old friend.
aemidnight 12-16-2006 04:03 PM
ok, got the windows working, need help with the inside door handle, how do i get a new one installed, and the part number for the rod connects the door handle to the door opening latch.
thanks.
Ron.G 12-16-2006 04:30 PM
Did the wiring I gave you work ?
aemidnight 12-16-2006 04:37 PM
i found an old thread that had the info on it...now if i can just fix the inside door handle all will be well, for today.
Hugh R 12-16-2006 07:20 PM
Do you know how to use the macro feature on your camera? Also you push half way down to focus, then all the way down to take the pic. Sorry, don't remember.
