por-tex's Avatar
Needing sandblasting/peening done on some engine tin in Houston any suggestions
I'm looking to have some sandblasting or peening done on my engine tin on my 3.0 that I'm rebuilding does anyone have a lead on anyone in Houston? The only places I've found are too large a companies and aren't interested in the work.
Old 04-30-2007, 07:59 PM
Harbor Freight tools- you can buy a box for less than $100 bucks. Rent a compressor for $40 and you can blast to your hearts content.
Old 04-30-2007, 08:06 PM
I second that recommendation. You'll use the equipment for lots of other stuff. I used a buddies set up at work and did everything myself saving the cost of buying the equipment but would have bought the box (I have the compressor) if I had to. I didn't trust someone else to sand blast my parts and ruin them.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 04-30-2007, 08:41 PM
If you happen to know an autobody shop, ask them. I can't see how any shop doesn't have a bead blasting booth. I've done these and they really are easy to blast quickly. And these only take a few minutes to do. I can't see buying all the equipment for a half hour of work.
Old 05-01-2007, 05:44 AM
I cleaned the headers, crossover pipe, muffler, pistons, valve covers, cam covers and I cannot remember what else. It took several afternoons to do. After cleaning I painted the exterior of everything with a high temp paint that I baked in the oven per instructions. 2 years later everything still looks great. I left you a PM.
Old 05-01-2007, 06:08 AM
Shaun @ Tru6's Avatar
Need recommendation on blast cabinet
Tru6 Restoration & Design
Old 05-01-2007, 06:10 AM
David's Avatar
Where in town are you?
Old 05-01-2007, 08:10 AM
I had some powder coating done at Allied Powder Coating. They do blast everything before hand. They may do just sandblasting. There prices do seem very reasonable for powder coating. You may want to consider having it powder coated especially if you are going to have to pay someone to sandblast your tin. They do have a minimum, can't remember what it was, possibly $100.00 So find all the things you want powder coated. It does look great.
Rob Richardson
1974 911S
Carbed RS Clone engine
Turbo flares
2009 Carrera S - Porsche Racing Green, PDK
Old 05-01-2007, 03:56 PM
David's Avatar
I'll second the powdercoat recommendation, that's what I did with mine.
Old 05-01-2007, 04:07 PM
