I don't know of anywhere else to get them.
I asked member widebody911 - Thom Fitzpatrick who was making f/glass or carbon fibre pieces but is no longer due to Parts Heaven starting up production of the metal parts. I think it was mainly the LHS duct with the indentation in it for the later larger diameter dizzies required for SC's & Carrera's. I thought I saw that they were quite expensive around $145 per piece but PRETTY. Any other leads on plastic/ fglass?
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Here's one from our host, but it doesn't have a place to hook up a hose from it to the tin. Where the tube comes through the tin would have to be capped off.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M§ion=VENTht&page=2&bookmark=4&part_number=PEL-PP910181
Bill 997.2 |
Bill I'm a little confused.
Using this part on an SC would disable the heat wouldn't it? How would the heat exchangers get air? chhers, Phil
I don't know how that would work with an SC. But I thought you just wanted something for the LHS SC OR Carrera? This was more for what I have on my Carrera. I get heat from the green arrows in pic by using the red levers in between the seats on the floor. I capped off the pipe (red arrow). When it's moving down the e-way, it pumps out good heat. It even gets too hot sometimes. Also, so far I haven't had any engine overheating issues either. This pic came from '84-'86 PET catalog from Porsche.
![]() Lets get back on topic for Oh Haha's SC......
Bill 997.2 |
Why not rotate the inlets on the heat exchangers [part 27 in red] so that they face upward and plumb the system like a 74? Bet they would even work on the Carrera's!!
![]() Of course, you still need to spend some money on the parts in red below: ![]() Also, I'm not sure its wise to block of the heat exchangers. Think about it..even when you are not using the heat, the engine fan is moving air thru them and pulling heat away from the engine. The factory obviously thought this was a good thing and included an over temp circuit on the carrera's that turned the rear heater blower on when the car was stationary to help push some additional air thru the heat exchangers.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Here ya go
damn the link isn't working..this is the Item number: 180064654568
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. Last edited by Mysterytrain; 12-20-2006 at 12:30 PM.. |
