-   -   correct Idle speed (http://forums.pelicanparts.com/porsche-911-technical-forum/320694-correct-idle-speed.html)
bcr4d 12-18-2006 02:30 PM
correct Idle speed
Hello again. My question is what is the ballpark idle speed for a 88 911. If I'm not mistaken, mine is around 850 to 900, give or take. The reason I ask is at times it seems to hunt for that comfort zone. thanks in advance.
Danny_Ocean 12-18-2006 06:37 PM
You are correct @ 850 ~ 900 rpm. When does it hunt? Mine only hunts upon initial start-up. After 30 secs., it settles in @ 900. If yours continues to hunt, I believe it could be a vacuum leak issue (among other things). Someone more knowledgable will most likely chime in soon.
bcr4d 12-19-2006 02:10 AM
reply
thanks for your reply. It basically idles at 900, but drops to 850 at all times. Just started recently. Is there a easy way to test the vacuum hoses?
