RLJ
Guest
Posts: n/a
Door speakers
What is everyones thoughts on the proper way to run speaker wires to the doors?
Randy Jones
1971 911
Old 10-08-2000, 10:46 PM
89911
Guest
Posts: n/a
Through a grommet close to the door stops. I had to rewire mine. Does'nt your have factory wire there? Just use the same openings.
Old 10-09-2000, 02:54 PM
89911
Guest
Posts: n/a
[This message has been edited by 89911 (edited 10-09-2000).]
RLJ
Guest
Posts: n/a
There was never any door speakers in this car so I get to be the first. That's why I'm askin!
Randy Jones
1971 911
Old 10-09-2000, 03:54 PM
89911
Guest
Posts: n/a
Well then, just look at a later model's wiring route and duplicate this. You will need a flexible drill shaft most likely to drill the doors.
Old 10-09-2000, 09:00 PM
