| Registered Join Date: Mar 2009
				Touchy Gas Pedal
			I have a 1984 911 Carrera. The gas pedal is very sensitive on it. It is impossible to cruise steadily unless you keep the car in high rpm's, and even then not always. The gas pedal is just too touchy. Even if you just barely touch the pedal it is accelerating, and the only way to stop is to take my foot off the pedal completely. Is there any way to this sensitivity? Thanks. | ||
|  01-05-2010, 09:18 AM |
| Registered Join Date: May 2004 Location: Encinitas (San Diego CA)
			I can think of two solutions, assuming the engine is tuned properly: 1. you can change the ratios of the throw arms at the transmission bellcrank. This will change the rate at which the throttle plate responds to your inputs. While involved, it may be necessary, if you can't live with the stock ratios. This would require some simple fabrication and also adjustment at the pedal to make sure you still can access WOT. 2. you could add a heavier return spring at the throttle plate. This might allow you better modulation. Doug
				__________________ 1971 RSR - interpretation | ||
|  01-05-2010, 09:22 AM |
| Registered |
			The throttle linkage on top of the engine (under the intake manifold) has two return springs. Check to see if both are in place. One might have come loose or broken.
				__________________ '88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 01-05-2010 at 12:06 PM.. | ||
|  01-05-2010, 11:46 AM |
| Go Speedracer, go! Join Date: Aug 2002 Location: Indianapolis
			I had a similar problem. It ended up being worn carpeting interfering with the gas pedal.  I also had a similar problem caused by an improperly adjusted clutch.  The clutch cable was rubbing on the throttle crank by the transmission causing the throttle to feel really light and touchy.  Just a few things to check.
				__________________ 1981 SC ROW Coupe | ||
|  01-05-2010, 04:39 PM |
