-   -   Another name identify part game. (http://forums.pelicanparts.com/porsche-911-technical-forum/320985-another-name-identify-part-game.html)
Kroggers 12-20-2006 09:45 AM
In the process of undertaking some general rust repair, I removed the bumper to find this tube hanging out from the front of the car. I followed it back, and it goes to the small metal pipe under the fuse box, and on to the petrol overflow container in the front wheel arch. Can someone please inform me if this tube is going to the correct location, and what it is intended for???
http://forums.pelicanparts.com/uploa...1166636584.jpg
http://forums.pelicanparts.com/uploa...1166636631.jpg
http://forums.pelicanparts.com/uploa...1166636693.jpg
:confused: SmileWavy :confused:
JackMan 12-20-2006 10:10 AM
Wild Ass Guess
This tube pulls gasoline vapor off the the overflow tank and vents the fumes over the front of the car in an effort to melt ice off the headlights????? Nahhhhhh, what is it?
kycarguy 935 12-20-2006 11:16 AM
Its the super secret video camera to peep into unsuspecting tailpipes. ;-)
dweymer 12-20-2006 11:26 AM
i think it is just a vapor vent
randywebb 12-20-2006 11:46 AM
what year car??
I thought the evap. emissions stuff was a sealed system - yours may be for a '68 or earlier - check the hole ot see if it looks factory too
Like the idiotic way that P AG ran fuel and vapor lines right next to the electrics? Maybe it was part of their "Force you to buy a new car" campaign... Excellence was Expected (but not Achieved in the Electric System)
Kroggers 12-20-2006 10:03 PM
Hi Randy. It does look factory, but I am not sure it is factory :) The car is the 78SC in my signature... If it is for venting, then why run it all through the car to end up outside not far from where it started!?! Would it not be better to run the tube directly out and down next to the overflow tank instead of back into the car and out the front again?
randywebb 12-20-2006 10:17 PM
something may bewrong - all US SC's have the evaporative emissions system - dunno re Euro's
I'd put it back the way it should be - search on those 3 terms for some diagrams and info -- there are several threads on it.
pwd72s 12-20-2006 10:21 PM
Early cars have a brake fluid overflow that exited through there, but that was clear plastic, led to the brake fluid reservoir. Possibly a P.O. did a little modifying to simplify the evap system?
dweymer 12-21-2006 12:16 AM
http://forums.pelicanparts.com/uploa...1166688977.jpg
javadog 12-21-2006 04:02 AM
It is a factory installation and the hose is where it is supposed to be. There would originally have been a little metal tab spot-welded to the front of the tub to hold the black plastic end of the hose. It's a Euro thing, as the cars for that market didn't have the same evaporative emissions system as a US car. I have no idea why Porsche routed the hose the way they did.
JR
Kroggers 12-21-2006 07:12 AM
JR
Thank you JR, that is good to know. So as I am going to do some work and upgrades, is there a better routing I could do with the tube - like not going all the way round the car :rolleyes:
javadog 12-21-2006 11:08 AM
Pal,
You could re-route it, I guess, but I just leave most things the way the were built. You might want to add something to secure it to the front of the tub. There was originally a little strip of metal spot welded to the tub just to the inside of the left bumper support mount. It would be like those little metal tabs that you see all over the tub that hold the wiring harnesses in place.
JR
Kroggers 12-21-2006 10:07 PM
OK, thank you JR :)
