Elombard's Avatar
Whats the scoop on the new ER rear suspension?
Anybody have the details or more pictures from Ventura? Did I miss it? I dont see anything at the website.
Chuck Help! :-)
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-12-2006, 03:33 PM
3.4 Bigger is better
88-diamondblue's Avatar
I was also hoping to see some pictures of all the new "need to have go fast goodies" . Looking forward to seeing what is new..
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-12-2006, 04:57 PM
Chuck Moreland's Avatar
I was so busy at the show, I never did take any pictures. But lot's of people did, maybe someone can post.
My website isn't updated yet. I've got no time right now, but I will try to post some more pics / info shortly.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-13-2006, 11:15 AM
Peter C2's Avatar
Chuck, Got any pics and additonal info? Thanks!
'71 911T => POC #388 GP
'89 928S4 5spd/LSD Baltic Blue Metallic Track Shark (SOLD)
'91 C2 Coupe Black/Black (SOLD)
Old 09-15-2006, 02:05 PM
lateapex911's Avatar
All I can say is that it better not be way trick, cool or a vast improvement, as i just upgraded mine to the WEVO SPS system.
But I know your stuff Chuck, so I realize that I have little hope, LOL.
I only hope it's expensive!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 09-15-2006, 02:40 PM
Elombard's Avatar
At least tell us what it is. 4 link with T bars or have to go to coil overs in the back?
Estimated price?
ETA?
Old 09-15-2006, 02:43 PM
any more info???
Old 09-17-2006, 08:21 PM
I am subscribing.
Old 09-17-2006, 09:42 PM
ttweed's Avatar
Chuck Miller posted this pic of it at the Early S Registry site:
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 09-18-2006, 05:44 AM
Thank god it won't be available for SWB cars (will it?)
Robert
Currently Porsche less (but the wife has 2)
Old 09-18-2006, 06:00 AM
Thats interesting. looks like it keeps the trailing arm, but changes the spring plate to eliminate the cumbersome toe and camber eccentrics.
At first glance, you'd think "4 link", but it doesn't appear so.
It looks like the bushings are probably poly bronzes with a specific retainer. I hope Chuck checks in here to tell us how it works. I assume it's height, toe and camber adjustable.
Old 09-18-2006, 06:59 AM
Elombard's Avatar
Wow...that looks like not an inexpensive option. How much camber can you get with that bad boy I wonder.
Old 09-18-2006, 07:01 AM
Diss Member
Quicksilver's Avatar
It is a 4 link of a slightly different bent...
The bottom link bolts to the stock torsion bar link, which acts as the forward pivot for the bottom link. The top link attaches in front and to the outside of the torsion bar bushing. This position of the upper link increases the camber curve.
It can be a little hard to visualize but if you imagine this taken to an extreme it is pretty easy to understand. Imagine if the upper link was attached where the hole in the fender for the t-bar is located. It is pretty easy to visualize that this would make the upper link swing inward as the suspension moves upward thus increasing the camber change.
Chuck's design is a fair bit less aggressive then that. One of the cool things is if you shorten or lengthen the upper and lower links by equal amounts you are changing the rear toe. If you change the upper and lower lengths in opposite but equal amounts, you are changing the camber. Pretty slick.
One thing that I am still noodling over is what the changes in the pivot point will do to the spring rate. It will change it slightly but the change will be very small.
I would like to see how durable it is in a destruction/abuse situation. An offroad rally test and the aftermath of a couple rear corner collisions would be nice to see.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-18-2006, 07:19 AM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
And what about the $$$$ - how much??
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 09-18-2006, 07:28 AM
Par911's Avatar
you know what they say, if you have to ask.....
Old 09-18-2006, 07:43 AM
Elombard's Avatar
i cant visualize how changing the lengths affects camber, seems like it would just rotate the axle housing? On the stock set up you physically move it upward to change camber. I am sure it works just cant picture...
Oh wait, I see if you shorten the upper arm the camber curve is stronger. So its best of both worlds. Less camber strait ahead, as the car rolls in a corner you get more camber than the stock set up for increased contact patch in both situations??? Right?
Old 09-18-2006, 08:10 AM
Yea, it's pretty shrewd, I'll say that. Not a classic 4 link, but it does appear to solve some issues all at once, and that's always a good design. I was unsure of the upper pivot point, as it's hidden from view in the pic. How is height adjusted?
Old 09-18-2006, 08:23 AM
Elombard's Avatar
It looks like you adjust the height same as before, with the ecentric oblong bolt up near the T bar.
Old 09-18-2006, 08:53 AM
Glad to see all the interest! Some of the speculation is on the money.
Here is the display that was at GAF:
And a little animation from the CAD assembly drawings:
The product name is ASP (Adjustable Spring Plate). It works with torsion bars or coil overs and any standard spring plate bushing. Supports factory AL or steel trailing arms, currently LWB only but SWB is on the horizon.
It's function is to make the camber curve more aggressive (as was done in the 993), thereby achieving a superior contact patch and superior grip.
The aggressive curve achieves optimal camber in turns without requiring the excessive static camber traditionally needed to make the stock setup work. It thereby avoids the many negative consequences of running lots of static camber (excessive tire wear, poor contact patch for braking and acceleration, rolling resistance, and off camber inside tire in turns).
The net result is superior grip. And the ability to go from street to track without running "compromise" alignment settings.
A secondary benefit is ease of setup. Static camber and toe are set using the upper and lower double-adjusters. Turn them both the same direction to set toe, opposite direction to set static camber. The adjustments are performed with the vehicle weight sitting on the tires, and can even be performed with the vehicle flat on the ground. You can just reach under and turn the adjusters.
I am not exaggerating when I say the ease-of-setup is a dramatic improvement. DRAMATIC.
The product is in testing now. I had it out to couple PCA Autocrosses this past weekend and pulled TTOD on Sunday. I'm taking it to Buttonwillow this weekend for some big track excercise.
Planning price is $1200/set, the Polybronze adds about $300 to that.
Old 09-18-2006, 01:03 PM
Elombard's Avatar
Neat so my poly bronze will work with this.
How did it "feel" at the autocross course was it significant?
I guess the benefits run deep
ease of set-up
potentially run less ARB
potentislly softer rear springs
The last two might make a huge difference on a track car and optimize the contact patch or am I off base.
Old 09-18-2006, 01:29 PM
