-   -   Need Mechanical injection kit (http://forums.pelicanparts.com/porsche-911-technical-forum/32120-need-mechanical-injection-kit.html)
VIPRKLR 10-11-2000 09:49 PM
I have a 2.7 CIS and am going to build it up to RS specs. First order of business is to locate a mechanical fuel injection setup as I hear that the CIS wont work well.
Also, since the motor has about 130K, should I replace the case, or simply do the RACEWARE studs and Timezerts? I have heard that there is an aluminum 2.7 case, but have yet to confirm that.
Ideas would be much appreciated here as I know so little and am about to go into DEEP water$...
RarlyL8 10-12-2000 07:09 AM
I have no idea if this applies, but I have a complete MFI from a 2.4L '73T (minus the cam drive). Surely it is not the same as the famed 2.7RS but maybe can be adjusted or modified. Someone out there may know.
A friend of mine has a '76 with a 2.7RS spec motor running Webers. This is a very nice setup you might consider if the MFI proves a bit mutch.
campbellcj 10-12-2000 08:08 PM
You might want to give Gus Pfister at Pacific Fuel Injection Service (San Fran) a call. He won't charge you anything to answer a few questions...after that, hang on to your wallet, but he's THE MFI guru.
dave cardone 10-13-2000 12:27 PM
try my mechanic... he's built several RS clones, and was a factory Porsche employee during the 70's.
Andy Bittenbinder
412 366-6165 in the pittsburgh area.
Tell him Dave Cardone referred you, and good luck! I'd like to stick an RS motor into my 912E some day. Imagine that with a 923 gearbox!!!!
VIPRKLR 10-14-2000 09:43 AM
Thanks fellas - I will make some call this comming week.
Anyone ever hear of an aluminium 2.7 case?
Do I really need to replace the case if the timezerts and RACEWARE studs are installed?
I appreciate all info here!
ohecht 10-14-2000 02:06 PM
you may also want to read the information on the Paulweir.com website. There is an extensive explanation on the rehabilitation of the 2.7 Magnesium case using new studs, inserts, and a linehone.
Here's the link: http://www.paulweir.com/rebuild/27litref.html
Olivier
'82 SC
[This message has been edited by ohecht (edited 10-14-2000).]
72SMFI 10-14-2000 04:25 PM
You would need S throttle bodys and any MFI pump. The pump can be rebuilt to RS specs You would want a rebuilt rack set up for a rebuilt motor. It will set you back about a 1000.OO for a rebuilt rack.Also the throttle bodys will need rebuilding.More money.What I cant remember is, What to do with the pully that drives the mfi pump.Any how it will cost big bucks to do it. You might be better off going carbs.
