JackOlsen
Guest
Posts: n/a
915 Transaxle and Torque
This came up in the supercharging discussion, but I think it merits its own topic. In upgrading engines (via supercharging, turbocharging or swaps), does there come a point where you stand the risk of ruining the 915?
I have read that the 915 was designed for a maximum of 300 Nm of torque. I know that the engine I just mated to my transaxle puts out more than that. Are there any horror stories out there of stripped trannies? Did different versions of the 915 have different limitations?
Jack Olsen
1973 911 T sunroof coupe
Old 10-15-2000, 01:31 PM
H20911
Guest
Posts: n/a
the magnesium case was used from 72-77 and the case can break or the main shaft.
In 77-78 the input shaft size was increased and the case material was changed to alum. in order to hold up to the new 3.0 engine.
At that point (78- ) your weak links became the clutch holding power and relativly short gear ratios for higher HP engines.
hope it helps,
s
[This message has been edited by H20911 (edited 10-15-2000).]
Old 10-15-2000, 02:18 PM
Early_S_Man
Guest
Posts: n/a
Jack,
Bruce Anderson's 'Handbook' shows several 915 gearboxes modified with an electric pump to filter the gear oil and squirt oil on the ring & pinion, and gear clusters ... in application with Turbo engines.
It might also be time to consider SWEPCO 210 gear oil with extra moly ... intended for overloaded gearbox applications.
Warren Hall
1973 911S Targa
Old 10-15-2000, 04:32 PM
JackOlsen
Guest
Posts: n/a
Swepco 210 it is, then, at least as a first step. Any idea on sources? I don't see the heavier duty stuff on the Zims site.
Actually, having done a quick search, I also see Swepco 212, which is listed as having added Molybdenum Disulfide. Is this the one I should put in there?
Jack Olsen
[This message has been edited by JackOlsen (edited 10-15-2000).]
Old 10-15-2000, 05:21 PM
kurtstarnes
Guest
Posts: n/a
Jack:
With my 2.7L race motor (approx 250hp) I had the 915/12 (7:31) tranny rebuilt with a kevlar clutch disk and a taller 5th gear. Oh yeah - I needed a new case as well! Old case was fracked. Flywheel was fine but I'll probably wish I had coughed up the extra $s for an aluminum one.
I am told that this 915 tranny should be more than capable of handling the power.
This 911 will primarily be a "sleeper T" street car - and I have been told that a tranny cooler was not needed.
Best to you,
Kurt
http://www.911restorations.com
Old 10-15-2000, 11:55 PM
JackOlsen
Guest
Posts: n/a
Kurt
Did you put the 2.7 engine in the 72 T on your webpage? That is a beautiful car -- I think I first saw it when you had it listed on eBay a while back. Really great photography of it, as well.
What difference does the 5th gear make? What's the rpms, for example, at 70 on it? And have you tested for a top speed? That's the only area where I'll miss the taller ring and pinion, although I don't know where I'd ever test it out. My insurance is bad enough as it is.
Old 10-16-2000, 12:30 AM
garrickl
Guest
Posts: n/a
I have a 1978 930 which has had a 1986 915 transmission since 1993 with no problems. There is a shop here in California that does these conversions regularly without problems. I have been told not to stand on first gear ..... which I have not, and there have been no problems. The transmission is a little noiser than the 930 box, but 5 speed is much more driveable than 4.
[This message has been edited by garrickl (edited 10-16-2000).]
Old 10-16-2000, 12:32 AM
kurtstarnes
Guest
Posts: n/a
Jack:
Thanks for your kind words. I must say I spent a good hour admiring your car at your website and enjoyed the information you provided.
I hope to have answers for you before Christmas regarding my 911.
The mods are currently being performed.
Motormeister is doing the work - and yes I have read every thread in here about these folks!
So far, my experience with Roy has been great and I will keep you apprised of the project. Because this is a high $ project, I have been told that Lee is building this engine himself.
The proof will be in the pudding, so to speak.
Best Regards,
Kurt
http://www.911restorations.com http://www.starnes.com
Old 10-16-2000, 12:55 AM
RarlyL8
Guest
Posts: n/a
The longevity of the 915 in high performance applications depends directly on how it is used (or abused) by the driver. I have a buddy who modified and dragraced his SC. 191HP to the rear wheels on 245 wide tires with a posi resulted in 2 scattered 915 trannies. If you put out more than 200 ft/lb of torque AND plan to drive it hard expect problems. On the other hand, a turbo is easier on the tranny than a supercharger. SOOOOO - if you have a supercharged SC and you want to get all you can out of it you may want to consider a 930 tranny.
Old 10-16-2000, 07:30 AM
