Guest
Posts: n/a
Cut off Switch
One of my weekend projects is to clean up some wiring left from the PO's radar detector....
While in there I was going to install a cut off switch I assuming a simple flip switch from radio shack will do? Also there is a tech article on pelican tech section....is this applicable to a 911SC 1982???? Has anyone installed their own switch..lif so any info would be very helpful MJ |
Guest
Posts: n/a
Uh, does the technical article on this only apply to early 911s?
It's here. ------------------ Jack Olsen 1973 911 T sunroof coupe [This message has been edited by JackOlsen (edited 10-16-2000).] |
Guest
Posts: n/a
a switch in line to a coil" wire worked well for me . Hid it under the emergency brake boot
Guest
Posts: n/a
I put in a key switch ($30) made just for that purpose. Shuts down power to the starter and ignition. Can mount anywhere and, of course, you need a key to activate it.
