-   -   Difference Between 930 / 911 Trailing Arm Offset (http://forums.pelicanparts.com/porsche-911-technical-forum/321686-difference-between-930-911-trailing-arm-offset.html)
North Coast Cab 12-26-2006 04:56 AM
What is the difference between the 911 and 930 trailing arm in terms of required wheel backspacing? I think it's about 2", but I also know the 930 uses about a 1" spacer from the factory. So, I beleive the ultimate difference is about 3", but can someone confirm?
T77911S 12-26-2006 07:29 AM
i just posted a question about spacers. looking at my brothers 930 and my 911 w/turbo body and 9x16's, it looks like the 930's track is 2 inches wider, 1 inch per side. my rims sit inside the fender about 2" and his sit inside about 1". we both have 1" spacers.
ttweed 12-27-2006 07:50 AM
Cary from ERP states in this thread that the difference in offset on the turbo arm is 22mm, which is very close to 1 inch (25.4mm). I believe he would know the correct answer as well as anyone.
TT
