"C-Rations"
JRISER's Avatar
Bulb Holders
Does anyone have or know where I can get the bulb holders for the "city lights" that go inside the H4 housings? I believe they are the size that takes the 4w bulb and are probably identical to the US side marker light bulb holders.
Also, I did not have any pictures to help clarify things, so if anyone has some pictures of the items in question and could post them, I would be grateful. Thanks!
John
The Stable:
1985 Carrera Cabriolet (RoW) Sold
2002 Chevy Tahoe LT (The Wife's)
1999 Chevy Silverado (Parts Hauler)
1969 Volkswagen Beetle (Purchased From Original Owner)
I'm slower than the guy in front of me, but faster than the guy in back of me.
Old 08-06-2006, 04:49 PM
Used Up User
imcarthur's Avatar
The H4 upgrade kit from Pelican comes complete with socket & bulbs.
Di you get a set without? They look molded in so you might have to fab something.
Ian
'87 Carrera Cab
Old 08-06-2006, 05:45 PM
"C-Rations"
JRISER's Avatar
Ian,
Thanks for posting the great pics.
Since my car is an RoW model, it already has the H4's. The bulb holders, which simply push into that hole and are held in place by an extension of the copper ground clip, were removed during the federalization process. It would be nice to locate a source for these, since our sponsor does not seem to carry this item (unless you want to buy another set of H4's).
Anyone?
John
The Stable:
Old 08-06-2006, 07:37 PM
Used Up User
imcarthur's Avatar
It's a Bosch kit, so that is the direction to look. But it might be a simple part from some obscure OEM.
Ian
'87 Carrera Cab
Old 08-06-2006, 09:49 PM
ruf-porsche's Avatar
If you do locate a source for the bulb holder let me know. I have been trying to find one for the past three years. I even asked people going to Hershey to be on the look out for any vendor that might have them. Pelican does sell the side bulb holder, but it is a different size.
Old 08-07-2006, 04:39 AM
"C-Rations"
JRISER's Avatar
Ruf-Porsche,
I did not see the holders for the side marker lights in our host's catalog. I do, however, think they are actually the same size holder; I recently took apart a pair of side marker lights, and they looked identical to the size that should fit. Also, they are designed for the same wattage bulb, 4w. Now if I could just find a source, or someone with two that are in like-new condition I would be set.
John
The Stable:
Old 08-07-2006, 07:03 AM
You may or may not want to modify your H4s (they're fairly common), but you could install a generic bulb holder (there are probably thousands) and modify the mounting hole to fit. Just an option. Maybe something to hold a low wattage LED bulb. Optical alignment isn't required; it's just a running light for visibility (not yours).
Sherwood
Old 08-07-2006, 12:47 PM
"C-Rations"
JRISER's Avatar
Hey Sherwood,
Thanks for the suggestions. Yes, I may end up doing something like that, but will try and buy these from one of our members first.
Anyone?
John
The Stable:
Old 08-07-2006, 01:06 PM
"C-Rations"
JRISER's Avatar
Ian,
Do you think you could pull that holder out and get a part number off that? I have a Bosch dealer in town, and he said a number would definitely help. He thinks this holder was used on other cars as well. Thanks!
John
The Stable:
Old 08-07-2006, 01:09 PM
Originally posted by JRISER
Ruf-Porsche,
I brought the bulb holder from Pelican Parts and it was too small. They look identical, but the side marker light bulb holder is smaller than the H4 city light bulb holder.
Old 08-07-2006, 07:21 PM
Used Up User
imcarthur's Avatar
John
I can't have a look until the weekend. I have to go out of town early tomorrow. Email me Thurs to jog my feeble brain & I'll have a look. cab87 at rogers.com
Ian
'87 Carrera Cab
Old 08-07-2006, 07:37 PM
"C-Rations"
JRISER's Avatar
Ruf-Porsche,
Where did you find the holders on this site? I could not even find the side marker holders. Man, they sure look the same to me. Thanks for the info, and are they 4w bulbs? I would guess that they would be.
John
The Stable:
Old 08-07-2006, 07:42 PM
"C-Rations"
JRISER's Avatar
Ian,
Will do, thanks! Have a good trip.
John
The Stable:
Old 08-07-2006, 07:43 PM
Used Up User
imcarthur's Avatar
Here is the socket with bulb:
Without:
No markings except for the #10 on the bottom - on the white insulating part rather than the metal housing. You can see the 'bump' on the side that lines up with a groove on the H4 hole to slide it in. It takes a std 4W 12V bayonet base bulb. The hot is a spade male on the bottom. Grd is via the copper spring clip that also holds the bulb down.
Ian
'87 Carrera Cab
Old 08-11-2006, 04:51 PM
"C-Rations"
JRISER's Avatar
Ian,
Thanks for posting these great pictures. I hope someone has a pair to sell. In the mean time, I will send these pictures to the Bosch distributor and see if he can come up with something. I am hoping this was used on other cars as well.
John
The Stable:
Old 08-12-2006, 09:31 AM
The picture show the City bulb holder (bulb is in the holder) and the bulb holder that I brought from Pelican Parts. The PP holder is smaller and the bulb doesn't fit the holder.
Old 08-12-2006, 04:58 PM
"C-Rations"
JRISER's Avatar
ruf-porsche,
Thanks for posting the pics that clearly show the difference between the two. Now, if I could just find the source! Since they still sell the H4's, they (Bosch) must be making them.
John
The Stable:
Old 08-12-2006, 05:02 PM
I think the later H4 headlight does not have the city light bulb in them anymore at least the USA version.
Old 08-12-2006, 05:29 PM
"C-Rations"
JRISER's Avatar
Problem resolved!
John
The Stable:
Old 10-06-2006, 08:04 AM
Dixie Boost Hooligan
turbo3six's Avatar
Problem resolved? How? Were you able to source Bosch city light bulb sockets?
72 911 T 3.0 / 73 911 3.0 turbo
74 BMW 2002 TI
79 930 / 84 911 Turbo / 2010 Cayenne GTS
87 911 Carrera Coupe / 87 911 Turbo
94 911 Turbo 3.6 /17 911 Turbo / 18 GT3 / 22 GT3
Old 12-27-2006, 02:58 PM
