-   -   under dash wiring question (http://forums.pelicanparts.com/porsche-911-technical-forum/321933-under-dash-wiring-question.html)
bob deluke 12-27-2006 05:40 PM
Does anyone know what goes on term 56 with black/white wire on light switch? Also, is this yellow wire connection correct? It goes to the hi-lo beam stalk on the steering column. Does yellow female spade go to term 56? If so, where does yellow male space connector go? Oh, its for a 77 Targa. http://forums.pelicanparts.com/uploa...1167269738.jpg http://forums.pelicanparts.com/uploa...1167269840.jpg http://forums.pelicanparts.com/uploa...1167269943.jpg
Formerly Steve Wilkinson 12-27-2006 06:30 PM
Say again???
RoninLB 12-27-2006 10:16 PM
http://forums.pelicanparts.com/uploa...1167286612.jpg
Ove 12-28-2006 12:14 AM
Bob,
Take a look here:
http://forums.pelicanparts.com/showthread.php?s=&threadid=321499&highlight=termin al+designations
From the list:
56 Headlamp
56a High beam, high-beam indicator lamp
56b Low beam
56d Headlamp-flasher contact
Yellow is the color of the low beam output on the hi/lo beam switch on the steering column.
eaipvc 12-28-2006 02:59 AM
Bob,
I just replaced my turn signal/high beam switch and had the same question regarding the yellow wire. My old wire bundle (88 Coupe) came out and had the yellow wire exiting the harness and connected, what seemed like, to itself and going back into the harness. That's the way I installed the new switch and haven't found anything that doesn't work yet.
unimog406 12-28-2006 07:57 AM
the yellow wire is the auto-eject seat, be careful not to cross it
bob
bob deluke 12-28-2006 01:33 PM
Very funny unimog, you have been watching too many james bond movies......
RoninLB 12-28-2006 02:20 PM
Hey Bob
E4 "dimmer beam" is hi or low beam headlights.
