SMC SMC is offline
OIL viscosity and leaks?
I just changed my oil last week, I was running 15-50 Mobil 1, I put in 0-40 Mobil 1 and now I'm leaking oil.
Would the this change in viscosity cause the leak?
1988 911 Carrera
1970 911T
1972 911E Roller
Old 12-26-2006, 09:55 AM
SMC SMC is offline
bump
1988 911 Carrera
1970 911T
1972 911E Roller
Old 12-28-2006, 06:58 AM
Somatic Negative Optimist
Gunter's Avatar
Where is it leaking from?
Why would you run 0-40 in CA?
In your climate, I would run 15W40 DINO oil.
I like it because it's a Diesel application designed for high heat and pressure.
That's what I use Spring and Fall here in BC with 20W50 during July/August.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-28-2006, 07:36 AM
Immature Member
dentist90's Avatar
It seems to me that if it leaks with low viscosity synthetic it will also leak with any other oil... maybe not as much. Might make the difference between weeping and dripping though?
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 12-28-2006, 09:56 AM
petrolblue83911's Avatar
I think it is possible that the change you made would make existing leaks noticable especially after a good long run when you let the engine warm up a bit
Old 12-28-2006, 09:58 AM
