-   -   CAT is Empty!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/322170-cat-empty.html)
VFR750 12-29-2006 12:34 PM
CAT is Empty!!!
Take a look at this:
http://home.att.net/~mgmccaffrey/CAT-empty.jpg
This is what I found after I pulled the cat off the muffler. The CAT is completely empty, except for this wire mesh. Light shines right through it.
As you may know, I have been contemplating a cat-bypass, and the promised 8-10hp gain and richer sound. I have spent the better part of two weeks heating, banging and ultimately cutting out the nuts and bolts to get this thing off. I destroyed my muffler straps, heat shield brackets, cut off every heat shield bolt head, and imbedded about 5,000 small, metal filings in my fingers. I spent ~$130 on air grinders, carbide burrs and dremel cutoff wheels....
So, with some humor, I share this amazing picture. After all that work, I guess my new Bursch Test Pipe is pointless. I already have a "test pipe".
Oddly, I passed an emmisions check last spring. Doubt that all of the ceramic blew out this past year. The muffler seems to be empty, so it's not in there either.
Porsche_monkey 12-29-2006 12:49 PM
That is actually very funny.
cary 12-29-2006 01:00 PM
Shhhhhhhh............It's a secret.
Porsche_monkey 12-29-2006 01:01 PM
No doubt removing that screen will gain you ten HP.
therotman 12-29-2006 01:04 PM
wanna do mine next?
VFR750 12-29-2006 02:21 PM
Absolutely!
But think of the weight savings: I don't need the heat shield any more. :)
Eric-325I 12-29-2006 02:24 PM
One helluva a hairball haning out that cat's mouth!
VFR750 12-29-2006 02:31 PM
I'd like to know what that metal is made of. It hung in there under high temps. Platinum???$$$???
Leland Pate 12-29-2006 03:47 PM
...that sounds like something I would do... sorry to hear of your bad luck.
joe payne 12-30-2006 06:33 PM
One of those simple jobs gone nightmare. I hate that! Anyway, wrap your new cat bypass with header wrap to cut down on heat and put it on.
It weighs less than the so called cat you have now. Just my two cents.
