911 sc non spark what look for?
Alina post deleted -Z-man.
The CDI box could be faulty as well as the coil itself. If all that is cool, check your green wire from the distributor. If it is brown and cracked, its possible that your CDI is not getting a trigger signal.
It could also be a grounding issue. Check you transmission strap as well as clean all your grounds. I'd check your grounds first. |
| All times are GMT -8. The time now is 02:45 PM. |
