carrera script application
I'm applying some side carrera scripts to my 911 and was wondering if anyone can give me some fitting advice.
I've had a search but can't seem to find much info. Thanks |
Theres a special decal spray that you can get at the auto body supply store. Stays wet and it lets you slide it around. Plus it comes with a big straight edge squeegee gadget. Really pretty easy. Like $12.00.
Theres a concoction you can mix up but I can't remember what it is. |
Use water with a squirt of dishwashing liquid in it. Mist generously with a sprayer before applying the decal and use a plastic squegee to force the air and water bubbles out.
Ulrich |
Thanks a lot, I thought water and soap would be the way. I used to do that with my model cars!
| All times are GMT -8. The time now is 03:12 AM. |
