-   -   Adding Power Windows (http://forums.pelicanparts.com/porsche-911-technical-forum/32262-adding-power-windows.html)
Nicky2 10-23-2000 06:58 PM
Could any one tell me what is needed to convert manual windows to power windows in a 1978 SC? Thanks
Early_S_Man 10-23-2000 07:23 PM
Just two parts from a salvage yard ... one left door, and one right door! Ha-Ha-Hee-Hee ...
Warren Hall
1973 911S Targa
BRAINIAC 10-23-2000 07:28 PM
The parts needed are as follows;
2 regulators
2 motors
2 door panels
3 switches
1 wiring harness (window system only, its separate)
Your best bet is to get these from a wrecking yard. The only hard part is the wiring harness routing. Make sure you watch as they take it out of the donor car. It's really a simple switch if you have all the parts. The doors are the same. E-mail me if you have any specific questions.
tog 10-23-2000 07:49 PM
On the other hand, somebody sells a kit (for $99 or $199, I think) that allows you to use the existing winder mechanisms and just inserts the power via a cable from an added motor and the appropriate switch/button to make it all work --- behind the door panel where the hand crank would go. I don't have any personal experience with these so I can't speak for their reliability, etc. and I can't remember who sells it but I could did around if you're interested...
