Narrow body wheel problem
Fellow Pelicanites... I've got a '76 911 narrow body with 6x16 Fuchs in front, and 7x16 Fuchs in the rear. Love the staggered look and performance, however, rear tires hit the wheel well. Any suggestions...add-on flares (maybe?), replace with 6x16 (I'd rather not, but...) ... HELP!
I'm subscribing. Just fitted the same setup with the same problem.
'77 911S w/'81 3.0/MegaSquirt/MSD '81 911SC stock |
up-fixing der car(ma)
tire size? how much negative camber? any spacer? 225 and -1.5 deg. should clear, of course this may depend on if your car was hit or what exact brand of tire you have
Scott Kinder kindersport @ gmail.com |
Don't mean to hijack but I have 225/50 in the back with Fuzions, know wheel spacers and camber is ?
Add flares,Then there will be no problem
Denny 1976 911s targa 1974 widebody G2 style GroupeB 76 www.G2Performanceshop.com Cylinder head recon, case savers,twin plug,rocker arms |
Bill MID9 #4 if i cant play with it ,,i dont want to own it |
