-   -   Adjustable spring plates install (http://forums.pelicanparts.com/porsche-911-technical-forum/323574-adjustable-spring-plates-install.html)
mmasse 01-07-2007 08:26 AM
I am about to install factory adjustable spring plate on my 76.
What should be the initial setup for the adjusters?
What I mean is, when I installed the non-adjustable ones, I just measured the angle before disassembly and try match when assembling, but I don't know how to set the adjusters in order to ensure that I have appropriate heigth adjustment when I am done.
Thansk in advance for your help
trak ratt 01-07-2007 08:37 AM
Set the adjusters in the middle position and install at same angle as old ones. The adjustment is for “fine tuning” so are used for final ride height/alignment/corner balancing.
dfink 01-07-2007 08:38 AM
Opinions may vary. I set mine with the adjuster neutral so I could go up or down as needed.
Gunter 01-07-2007 10:24 AM
In the middle like others have said.
Inspect the T-bars, use grease on both ends of the splines, they are marked L & R, make sure you understand the principle behind the 40/44 splines for indexing.
Use antiseize lube for the nuts/bolts.
Joe Bob 01-07-2007 10:31 AM
Good time to upgrade bushings and consider bigger t-bars....
mmasse 01-07-2007 11:29 AM
Thanks for the inputs.
Mikez, I already upgraded the T bars (30mm) and I am installing elephant Racing Poly Bronce bushing...look forward to drive when finish.
mmasse 01-14-2007 06:28 AM
Now, my rear end will be completed.
30mm Torsion Bars
Elephant racing PolyBronce bushings.
Look forward to test it
Here is a pic of the spring plate about to be install.
http://forums.pelicanparts.com/uploa...1168784919.jpg
Gunter 01-14-2007 08:10 AM
Looks nice, Mario.
For the bolts, use antiseize grease for the torque. (M16 = 177 ft-lbs.)
If washers are used, flat washer goes on first, then lock washer.
Set the shorter torque-plate in the middle (Eccenter lobe on bolt at 3 o'clock) so that the eccentric bolt can be adjusted up or down for the final height-setting/corner balancing.
Stock '76 axles are pretty small to take that kind of power.
What size/type CV's and axles are you using?
mmasse 01-14-2007 09:47 AM
I have stock CVs/axles.
I am in the middel of a tranny rebuild doing all the reommeded improvements to hadle the power (e.g 1 piece retaining plate, reinforced side cover, assymetrical 1ast with beefed up guide and slider...and oil tranny cooling with internal spray bar)
What axles CVs would you suggest?
Gunter 01-14-2007 11:41 AM
Porsche upgraded the CV's/axles to a bigger size in 1985, about one year into the Carrera 3.2 for obvious reasons.
I don't believe the larger flanges from '85-'86 can be bolted on an earlier 915. In 1987, the G-50 came in changing the set-up again.
I would start a new thread and find out what others have done to get stronger CV's/axles on a mid-year 915.
Stock CV's in '76 were designed for about 175HP, you can see that they are not really for a 3.6 liter with 280+HP.
Also, '76 had stock 15" wheels. If you have bigger wheels, it'll add to the torque exerted on the CV's/axles.
