Clutch cable came off. (pics)
Alright, I did a search and i couldnt find anything on this issue.
I lost my clutch, and after inspecting i found this. the cable came out of the retaining tab completly, im trying to get it it between the nuta again, but i just cant muscle the cable back that far. is there a way to get the tention off the cable so i can move it back? ![]()
71' 911T Targa, current toy. 86.5 928s traded for new 911 71 911 Targa w/ gas burners, PMO's, *sold* Lamborghini diablo replica w/ 350 V8 85.5' 944 n/a euro ( gave to dad ) 87 fiero cp. candy blue, chrome 16's 90' DSM 24psi. 18G fmic, 82' benz 300sd turbo, intercooled. 73' Karmann Ghia cab. sold 04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs, check out www.vintagevwcars.com wanted: 914, 944, 928 project Last edited by fierochris; 01-07-2007 at 12:11 PM.. |
Somatic Negative Optimist
Man, what a grease pit.
Yes, there is a procedure for adjusting the clutch (Including the cable) The C-spring tension needs to be released before you can move the cable-ends and the cable needs to sit in the tube inside the tunnel. I suggest that you first have a serious clean-up with steam perhaps? Get a Bentley Repair Manual for your 911. There is a Tech article on PP. You can do a search here but you'll love the Bentley.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
i got the cable loose. i just took it off where the cable end holds on the transmission case . i now have the cable housing set in place between the adjusting nuts. but i cant get the inner cables end knarp hooked again. i have the cable loose. but i need about another inch of travel. any idea how i can get this?
71' 911T Targa, current toy. 86.5 928s traded for new 911 71 911 Targa w/ gas burners, PMO's, *sold* Lamborghini diablo replica w/ 350 V8 85.5' 944 n/a euro ( gave to dad ) 87 fiero cp. candy blue, chrome 16's 90' DSM 24psi. 18G fmic, 82' benz 300sd turbo, intercooled. 73' Karmann Ghia cab. sold 04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs, check out www.vintagevwcars.com wanted: 914, 944, 928 project |
ok heres how things look now.
figure 1 shows the housing in its proper placement and the adjusting nuts with the retaining tab between them. figure two shows the cable itsself. i need to obtain about a inch more slack in the cable so i can get the knarp behind the flange on the trasmission. can anyone tell me how i can get more slack? the nuts are backed out all the way on the ajustment.
figure 1
![]() figure 2 ![]()
i still need more slack. does anyone have the answer? I really want to get my can back on the road.
have someone lift up on the clutch pedal. most likely it is on the floor.
86 930 42kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 05 BMW 330CI 130K:: [_ ![]() 08 VOLVO V70 190K:: [_ ![]() 90 B2200[__] RUNNING:[ ![]() ![]() |
Your Figure # 1 shows the cable coming down at what appears to be a rather sharp angle from the left. Are you sure you have the housing and cable routed properly?
good luck -
Thomas Owen 1972 911T |
Something looks weird. What year is this 911?
Post a clear pix of the levers etc. so I can see the rest of the clutch adjustment. Like this: ![]()
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() Last edited by Gunter; 01-08-2007 at 08:35 AM.. |
Ok is there anyone here that can help set me straight? i cant even find a picture of a tranny like mine. its deffenitly not even close to what gunther posted. I still dont have the slack in my clutch cable. i have the rear hooked up now. but now i cant get the cable close enough to the clevis on the clutch pedal to get a thread started. someone? Anyone?
Did you resolve the original problem which made the cable come apart?
The clutch you have is only found on a 70 or 71. You should have no problem putting on the cable end if 1: You disengage the plastic guide ( I don't know what the correct name is) from the release fork. 2: The stopnuts are positioned full loose, as you have shown. 3: The clutch pedal is wedged up. 4: You put the cable end into the attachment hole and slip on the retainer. 5: Last is push the plastic guide as far as possible onto the threaded cable sheath/stop nuts. Then engage the plastic guide onto the clutch release fork. PS I would consider upgrading this plastic guide to the metal one as the plastic will eventually break off the 2 tabs and strand you. Good luck Ed
'69 911E 2.7MFI '71 Volvo P1800E Wife's car '78 VW bug convertible Family car '02 M3 Winter car |
fierochris:
It would have been a lot easier if you would have stated the year/type from the beginning. Your signature doesn't help either: 86.5 928s *new baby* 71 911 Targa w/ gas burners, PMO's, *sold* I repeat, take a picture of your clutch levers (like my example) so we can see more. The cable is first attached to the front, then the rear in a certain fashion. The cable you have in the picture is missing the boot and looks kinked. If the cable is old, get a new one. If you want us to help, how us pictures as requested.
Thread Tools | |
Rate This Thread | |
