-   -   Source for sheet Lexan? (http://forums.pelicanparts.com/porsche-911-technical-forum/323615-source-sheet-lexan.html)
Formerly Steve Wilkinson 01-07-2007 12:36 PM
Anybody know a good source for coated (scratch-resistant) Lexan sheets, or maybe has some in the shop they'd sell me? I need just enough to do the rear quarter windows, which are coming out anyway to re-do the headliner, so I figured I might as well Lexan 'em. I already have the curved Lexan for the windshield and rear window, but stock 3/16" Lexan will be just fine for the flat quarter windows.
dd74 01-07-2007 01:00 PM
Maybe ask Chris Streit. I believe he sells Lexan pieces, though I don't know about whole sheets.
Formerly Steve Wilkinson 01-07-2007 01:15 PM
Only asked about "sheets" because that's the way it usually comes--typically two-by-four-foot pieces.
Quicksilver 01-07-2007 01:57 PM
Home Depot sells the stuff but I'm not sure how it is coated. If you are making windows you will want a good hard scratch resistant coating on it.
Formerly Steve Wilkinson 01-07-2007 02:06 PM
Yes, that's what I have on the windshield and rear window. they demonstrate it by actually sanding it, and it won't scratch.
Jeff Jagusch 01-07-2007 02:15 PM
try a plastics company
We have a local plastics company (Midland Plastics) that sells all kinds of plastics.
I know they have 4 by 8 sheets of Lexan, I'm sure they even have the scratch resistant type.
I bet if you look locally, you will find a buisness that sells it?
You would be amazed that the stuff they have!
Good luck
Jeff
jaydubya 01-07-2007 03:47 PM
Lexan is a brand of polycarbonate sheet. I think you want abrasion resistant polycarbonate sheet. Mcmaster Carr has it.
island911 01-07-2007 04:47 PM
That, I would like to see.
Unless they're 'sanding it' with wet news paper, I don't buy it.
please prove me wrong, but I believe that crystaline aluminum oxide (syth-sapphire) would be the only (clear) material to stand a chance against common sand paper. . . and you wouldn't find that on a thin pice of lexan. :)
gsmith4965 01-07-2007 04:48 PM
Lexan sheet source
Try Hoerr Racing Products. www.hrpworld.com
Formerly Steve Wilkinson 01-07-2007 05:40 PM
island 911, go to Speedglass Racing Windshields. Steve Weiner believes it, and so do I.
dd74 01-07-2007 06:03 PM
Stephan - please post whatever you find. If there's true scratch-resistant Lexan out there, I'd like to see it. Not knowing of a scratch resistant brand is the only reason I haven't put Lexan in my car yet.
As well, I'm going to check the links the other posters provided.
jaydubya 01-07-2007 06:08 PM
dd74 - check McMaster-Carr, type in "polycarbonate" into their search field, click on "plastics" on the right, then look down the list.
They also have "bullet resistant polycarbonate" :)
island911 01-07-2007 07:44 PM
Thanks for the link.
A very good friend of mine works for Honda R&D and was telling me about some lightweight window options. From the descrptions I think that the speedglass people are selling the same. . . essentially laminated glass with a very tick PC core, clad by relatively thin glass.
I could be wrong, but considering I design plastic lenses and such for consumer and medical products and often have the GE plastic rep in the office, discussing available plastics, I'm thinking I'm fairly current on plastic hard coats. --and we're not likely to find a 'sandpaper resistant' plastic sheet at HomeDepot.
Glass can certainly "resist steelwool" (as they claim) . .. but even glass is not going to survive sandpaper.
dd74 01-07-2007 08:15 PM
...well, given anyone would actually sandpaper their windshield...for whatever reason.
afterburn 549 01-07-2007 09:09 PM
Laird plastics in Seattle...1/2 or whole sheet
Formerly Steve Wilkinson 01-08-2007 05:42 AM
island 911 is right. They demonstrate that Lexan by "sanding" it with steel wool, not, as I wrongly implied, sandpaper.
Wavey 01-08-2007 06:05 AM
We use some Lexan for sign faces in my shop, and believe me, it will scratch. Try a screwdriver or utility knife on it. But to answer your original question Stephen, try any local plastics company, or sign supply wholesaler, or even try a local sign shop - they should be able to get it, might even have some scrap around. If you can't get it anywhere locally let me know and I'll get some to you.
Formerly Steve Wilkinson 01-08-2007 06:11 AM
By the way, island911, if you're interested I'll be happy to mail you a piece of the Lexan I'm using--a scrap from what I trimmed off the windshield--so you can maybe figure out what it is. If you wish, PM me your address.
island911 01-08-2007 09:46 AM
By the way, island911, if you're interested ...
That would be great.
Seeing that they sell over-sized windshields, I was curious as to how you got it to cut down. I imagine that it cuts fairly easily. (?) --that would exclude the surfaces from being glass. --hmmm.
Formerly Steve Wilkinson 01-08-2007 10:09 AM
Yeah, I just cut it with a 20-tpi Plexiglas blade in a saber saw and was able to sand it relatively easily with a belt sander, to true the small deviations in my initial cut. You'll see from my PM to you that I don't think it has any glass in it either.
Tim Hancock 01-08-2007 10:57 AM
FWIW, Mcmaster Carr lists regular polycarbonate at about $60 for a 1/4" x 24" x 48" pc and "abrasion RESISTANT" polycarbonate in 1/4" x 24" x 48" at about $120.
Why don't folks use plexiglass (acrylic) for the side and rear windows as it is cheaper (most hardware stores carry it) and more abrasion resistant than lexan (polycarbonate). Plexiglass will break unlike lexan, but for rear quarters and rear windows why would anyone care? Just something I always wondered about.
I have lexan in one experimental airplane and plexiglass in all the rest and the plain lexan definitely scratches easier than the plexiglass. Most general aviation windshields and windows are in fact acrylic as opposed to lexan believe it or not.
Formerly Steve Wilkinson 01-08-2007 11:25 AM
That's a very good point, and I think I'll simply go buy some Plexiglas for those quarter windows. After all, I've sat behind Plexiglass for over 3,000 hours in the air and it never bothered me...
