BMW Thermocouple Wiring Help
The thermocouple on my oil cooler needs to be replaced and I would like to put in the one made by BMW and supplied by our host.
My question is: how to wire the new thermocouple to the existing wires? I know it needs the spade connectors but what to do about where the ground and power wires are connected[?].
The oil cooler is out and this is my only sticking point.
As an aside, there has been some consternation expressed as to the difficulty in removing the oil cooler. The secret is to tilt the top of the cooler back [toward the rear of the car] and then lift it up and out-no grinding slots or cursing needed!
Thanks in advance for the help!
Drums
'89 G50 w/ 3.6 V-Ram-now Ca. legal!
FORMER Yosemite Chapter PCA V. P.
Old 01-07-2007, 08:12 PM
autobonrun's Avatar
What color is the thermocouple wire? If it is a type J (Iron/Constantan) thermocouple, the thermocouple wire will be red and white (ANSI). Red is always the negative and White would be the positive. IEC uses black and white as their colors for type J TC's. I'm not sure if the lead wire pulled from the instrument is the same color as the TC wire, but you can determine polarity by looking at the TC itself.
The attached link shows all the various thermocouples, J, K, T, R, etc. so you should be able to tell what's in there now. Being a German car, the color code could very well follow IEC rather than ANSI but it should be pretty clear if you can access the TC.
One other quick item. TC's generate their own millivolt signal based on the dissimilar metals used. There is no power to them. You should just be dealing with a positive and negative DC voltage signal.
http://www.omega.com/toc_asp/frameset.html?book=Temperature&file=TC_GEN_SPECS_REF
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 01-07-2007, 08:20 PM
Senior Member
Early_S_Man's Avatar
Porsche Crest
I don't think the item Pelican is going to send you is a thermocouple. It is probably a normal VDO thermal switch, just like the one used for radiator fans and oil coolers for VWs, BMWs, and Porsches.
Most likely the wiring Carreras normally use will work perfectly!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-07-2007, 09:25 PM
autobonrun's Avatar
Based on Warren's reply, my discussion of a TC is not applicable. A TC will give you an actual measurement of the temperature via an analog value. I thought you had verified it was a TC. If it is just a switch output, then the polarity should not matter.
2003 BMW M5
Old 01-07-2007, 09:44 PM
There was a thread where the BMW part was used but nothing was said about how to wire it up.
Maybe I will PM the author of that thread.....
Drums
Old 01-08-2007, 05:06 AM
Send a message via AIM to fierochris Send a message via Yahoo to fierochris
Cool
Originally posted by drums
Drums
Just noticed your sig. greetings from one drummer to another
71' 911T Targa, current toy.
86.5 928s traded for new 911
71 911 Targa w/ gas burners, PMO's, *sold*
Lamborghini diablo replica w/ 350 V8
85.5' 944 n/a euro ( gave to dad )
87 fiero cp. candy blue, chrome 16's
90' DSM 24psi. 18G fmic,
82' benz 300sd turbo, intercooled.
73' Karmann Ghia cab. sold
04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs,
check out www.vintagevwcars.com
wanted: 914, 944, 928 project
Old 01-08-2007, 05:18 AM
don't know if this helps, but my blue wire is the ground and is connected in the trunk. (labeled) It goes through he same grommet that the fog light wires went through. I used those water proff connectors that shrink with a heat gun. The brown (stock) wire connected to the other prong. I checked to make sure it was right before I tightened everything up. works like a champ but still hardly ever comes on. I used a blanket on th engine lid to check it. I think there's a procedure in the bentley to check operation also. Label the ground so that ten years from now you or someone else knows what that random wire is for.
Old 01-08-2007, 06:41 AM
Thanks, Jerry!
Just pick a connection on the thermocouple and run with it, huh? The wire colors are the same in your '87 as they are in my early '89, which made this easier! Thanks again!
Hey FieroChris,
Have you looked at the list of my 'drivers'? No reinforcing rings, 'fast' sizes with 'Burnt Toast' Satin Oil Fade......
Drums
Old 01-09-2007, 07:19 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
